Vishnu
70 -
9
Everything posted by Vishnu
Moin Martin, Thank you for your reply. I check your suggestion to uncheck the High DPI Override and it's already unchecked on my laptop. So tried by checking the check box and surprisingly now the menu bar seems normal. ^^ Do you think I can leave this check box checked? Cheers, Vishnu
Hallo again, The problem still exists. In addition to the main menu bar, the information bar at the bottom of the screen is too small to read. And it sometimes get really uncomfortable as the mouse clicks just do not work. I had to go to a different window and come back to PVSol. I tries reinstalling the software but it did not help.
Hello Frederik, Thank you for your response. It partially solved it. I can now see the main button bar but it is still with relatively small buttons. Is it possible to make it more comfortable like I see it in your screenshot? My PVSol used to be like that before I reinstalled it Cheers, vishnu
I have reinstalled my PVSol and ever since the editing options size has reduced and above all, no matte on which section I am, I see the same editing options. Could you please help me solve this issue. Thank you
Heya Team, I observed on the inverter config page that the module surface orientation is different in the new PVSol version. As you can see in the image, I have two module surfaces facing Nord-west and Nord-ost but the inverter config shows only Nord-west Is this something that has actually been changed in the new version or is it a bug? Thank you!
Hey Valentin Team, I tried simulating one of our PV systems with Fronius ECO 27 inverter, which as per its Datenblatt, has max input voltage of 1.000V The modules I used are SOLON R-WF 120p.2/370 with max Voc of 40,81V There is a warning that max Voc of inverter is crossed when I used 24 modules (24*40,81 = 980V) on one string. What am I missing here?? Thank you!!
To my knowledge, the system operator receives Ausfallvergütung only under special conditions, like when Einspeisevergütung or Direktvermarktung fails. Even then, the operator has to apply for Ausfallvergütung to receive the compensation. So these are very special cases and I don't think it's possible to calculate in PVSol
Hello Lukas, May I ask if you can share a screenshot of Financial analysis page or the project report? May be we can find out something Just curious to see what might go wrong -Vishnu
Connecting two modules to one power optimizer.
Vishnu replied to gytis.sauleselektrines.lt's topic in PV*SOL
Hey there, There was similar question on this forum already. Hope it helps -
Main input parameter for this is "electricity tariff from grid" which one provides as input
Hey Marcel, There is no undo function available in PV*Sol. I remember one of the admins mentioning that implementing undo function is pretty complex. We can consider ourselves lucky should it be on the wishlist -Vishnu
Hallo there, I was wondering if there is a possibility to add power price (€/kW) in addition to energy preis in PV Sol or is this still on your wish list? Thank you, Vishnu
You can get rid off them by setting the distance to edge to zero in "Edge distances"
- 1 reply
- 1
Hello Lukasz, You can only do that by selecting a 3ph inverter instead of a 1ph inverter. -Vishnu
Hi Miguel, To my knowledge I haven't seen any option in PVSol to set the life-time of the battery. May be PVSol considers the degradation of the battery which inturn impacts the efficiency and eventually the energy that can be stored in the battery. -Vishnu
Hallo PV Sol Team, Ja I know it's hard to get back to work after such a good Berlin weekend So talking business, we are planning a 15kWp system with 2xSungrow Hybrid HV SH6.0 RT inverters each of which gets one LG Chem Resu 10 batterie. However this combo is not readily available in PV Sol. I was wondering if there is an option to select only LG Chem batterie under batterie section as I can already simulate the system with the inverter. Also is there a possibility to simulate a system with two inverters having one batterie each? Thank you, Vishnu
Hello Ragy, I checked your system's configuration and I see there are 17 modules in a string and the modules have NOCT voltage of 39,8V which under NOCT gives 676,6V string voltage. The inverter's MPP voltage range is 570-850V. So as you expected it is possible that the string voltage is only slightly above DC start voltage of inverter (620V) To my knowledge, this impacts the efficiency and hence is high power loss due to MPP voltage range. This is only my opinion and the PV Sol team can give a better explaination Regards
Hey Ricardo, These are two different modules and there is no reason for me to believe that both the modules have similar anti-reflection coating and cell-surface polishing for Total Internal Reflection (TIR). I also see some difference in Module inclination and orientation losses. Of course it is marginal but this still could show some impact on reflection losses. -Vishnu
Hello Reint, It is hard to say why there is no significant difference between system with SolarEdge and Huawei inverter without info about your project. Have you tried comparing the Energy Balance sheet of both the systems? Optimizers would definitely reduce impact of shaded modules on the whole string. But Energy Balance would give better understanding Thanks, Vishnu
do you think the max DC input of the inverter is limiting the number of modules that can be connected to it during auto-cabling?
hey there, You may wanna check this thread from the Forum You can try to add modules from different buildings to "Define Module Area" and then configure them together. Hope that helps. I also see in some part of your simulation, you have only module in east-west pair. Someone was asking for his in the Forum -Vishnu
- 1 reply
- 1
Hey there, It follows the order Inveter.MPPT.String.Module Hope that answers your question. Cheers!!
I am afraid there is no concrete answer to your question. As long as you manage to convince your customer, I would say, any degree of shading is accepted
Thanks Martin for a quick reply. To be honest, I did not simulate this back then. I only re-ran it today. The original simulation file was from Feb 2020. I can tell you that. I used PV Sol v7 from April 2020 to re-run it today. I wish i could provide more info.Btw, i've also sent you a private message with files attached But ja, changes in simulation core explains it Thank you
i tried to record a similar video for one of our projects but the animation is available only for year 2017. is it possible to select the current year. i know, this may not make a big difference but, you know, marketing people can be really annoying to get these details right. no offense to marketing people reading this ?
