developer_mh
Administrators
    173
developer_mh last won the day on November 27 2025
developer_mh had the most liked content!
About developer_mh
Profile Information
  • Gender
    Male
13,831 profile views
developer_mh's Achievements
  1. Hi RSANZ, you can find the diagram editor on the "results" page, please refer to our help pages to find out more: https://help.valentin-software.com/pvsol/en/pages/results/diagram-editor/ Or in Spanish: https://help.valentin-software.com/pvsol/es/paginas/resultados/editor-de-diagramas/ Hope that helps, kind regards, Martin
  2. Hello RSANZ, you can set the feed-in limit to 0 so that nothing is fed back into the grid. Currently there is no option to limit the power that can be drawn from the grid, however. But you can see in the results after the simulation how much power has been drawn when, as a time series or carpet plot. That'd help to investigate if the system behaves as intended. Best, Martin
  3. Hi PVJames, thank you for reporting this. We already know of this behaviour, the percentages relate to single days as you already suspected. So if evenly distributed as in your first example, you'll have 31 portions in January and only 28 in February. See this thread here, there is an Excel sheet where you can prepare your data accordingly if you want to have an equal monthly percentage: We have planned to add this as an option to the dialog, so that users can choose between the daily and the monthly approach. Best, Martin
  4. Hallo, interessanter Fall! Ersteres geht, ja. Ist auch sehr einfach. Aber noch einfacher wäre, das über den Simulationsparameter Verschmutzung zu machen: Beste Grüße, Martin
  5. Hi Cameron, could you send us a project file where this happens? Please send it to hotline@valentin-software.com, along with a link to this forum post. Thanks a lot, kind regards, Martin
  6. Hallo DSchwer, danke für das Feedback. Wir sind auf jeden Fall weiter an der Entwicklung dran und daher auch sehr dankbar für Feedback. Das mit dem Zusammenfassen der Lastprofile aus Messwerten ist ein guter Punkt. Das ist schon früher so gewesen, um die Projektdateien nicht unnötig aufzublähen, da diese Lastprofile sehr groß sein können (groß im Sinne von Megabyte). Die Lastprofile aus Tagesverläufen hingegen kann man kopieren, vielleicht hilft das erstmal weiter? Eine weitere Möglichkeit für einen Work-Around wäre, sich nach der Simulation das Lastprofil ("1 Personenhaushalt") zu exportieren und dann als beliebig benennbares Lastprofil wieder zu importieren. Ebenfalls schöne Feiertage und einen guten Rutsch, viele Grüße, Martin
  7. Hallo Cordula, ja, mit dem neuen Feature "Es können jetzt mehrere Bezugstarife ausgewählt und unterschiedlichen Verbrauchern frei zugeordnet werden." Dadurch kann man für jede Mietpartei einen Verbrauch und eigenen Tarif festlegen. Die Ersparnisse werden dann auch separat für jeden Verbraucher (Mietpartei) ausgegeben. Beste Grüße, Martin
  8. Hallo Hisham, danke für die Anfrage. Klingt nach einem interessanten Projekt! Zu deinen Fragen: 1) Sinn macht es, ja. Zumindest macht man damit nichts kaputt. Ob die Einstellung Auswirkungen auf das Ergebnis hat, hängt vom konkreten Lastprofil ab, aber auch von Art der Anlage, der Orientierung etc. 2) Die Einstellung wäre diese hier: https://help.valentin-software.com/pvsol/de/navigationsseiten/anlagenart-klima-und-netz/#ac-netz. Dort Einspeiseabregelung aktivieren und auf 0 % und am Einspeisepunkt stellen Aber prinzipiell kann es sehr gut sein, dass nie abgeregelt werden muss, da der Verbrauch ja um ein Vielfaches größer ist als die Erzeugung duch die PV. Wenn ich mal ganz überschlägig annehme, dass die PV 900 kWh/kWp/a macht, wären das 1525 MWh/a. Im Kontrast dazu hat man 7194 MWh/a Verbrauch. Gut möglich (und wirklich vom konkreten Lastprofil abhängig), dass die PV da nie abgeregelt werden muss. Beste Grüße, Martin
  9. Hallo Marti, wie weit sind die Standorte denn auseinander? Innerhalb von einem PV*SOL-Projekt kann immer nur ein Klimadaten-Standort festgelegt werden. Wenn sich die Anlagen nicht allzu weit voneinander befinden, sollte das kein Problem sein. Dann einfach die drei Anlagen in einem Projekt (mit gemeinsamen Klimadaten) planen und einen Batteriespeicher anschließen. Beste Grüße, Martin
  10. Hallo Ray-AET, danke für die Frage. Könntest du mit Screenshots vielleicht noch genauer beschreiben, was du meinst? Was man in 3D machen kann, ist auf jeden Fall die Neigungs- und Ausrichtungswinkel von aufgeständerten Modulen beliebig einstellen, und aber auch Moduflächen mit unterschiedlichen Neigungswinkeln gemeinsam verschalten (Stichworte "gemeinsam verschalten" und "Polystring"). Beste Grüße, Martin
  11. Hallo zina, ja, wir können das Problem bestätigen. Das ist mit der Version 2026 R1 reingekommen und wird dann in der nächsten Version gefixt sein. In der Zwischenzeit einfach einen bestehenden Wechselrichter duplizieren, dann geht es. Beste Grüße, Martin
  12. Hi Dutch Energy Group, I guess you mean a limit for feeding energy into the grid? You can enter this in the options of the AC mains, we call it the maximum feed-in power clipping: The energy management is as described here: https://help.valentin-software.com/pvsol/en/calculation/battery-systems/#energy-management That means that right now, there is no specific option to wait for the solar power to reach the feed-in limit and only then charge the batteries. But we definitely have that on our plan, along with other interesting options that you have with battery systems. Or did you refer to limits for the power that is drawn from the grid? Hope that helps, best regards, Martin
  13. Hi Bruno Lalic, the difference comes from the low light parameters: left: "TSM-705NEG21C.20 Vertex N Bifacial 705 W" right: "TSM-705-NEG21C.20 VERTEX N 2024 705 W" In one case, the manufacturer has chosen the "standard low-light performance", which defaults to the two-diode-model for this module. In the other case, the manufacturer entered low light values himself, that is, defined values for voltage and current at 200 W/m². Hope that helps, kind regards, Martin
  14. Hi FPE, yes, you can do that in PV*SOL. If you have a load profile measured, you can import it in PV*SOL. If you don't have one, you can choose from plenty of options in the database. Then you would enter the schools current electricity price as a from-grid tariff and the "price sold to third party" as the PPA price. After simulation, you can see the resulting ROI and other financial parameters. Hope that helps, kind regards, Martin
  15. Hallo Niklas, das hat höchstwahrscheinlich mit der großen Menge an Wechselrichtern zu tun, die du in der Auswahl hast. Ich sehe da über 5000 in deiner Auswahl. Bei der Verschaltung müssen zu diesen ganzen Wechselrichtern die elektrischen Informationen aus der Datenbank geholt werden, und das dauert bei der Menge eben ein bisschen. Ich würde empfehlen, die Anzahl Wechselrichter in der Auswahl stark zu reduzieren, dann sollte alles auch wieder schneller gehen. Beste Grüße, Martin
