July 9, 20197 yr comment_2734 Hi PV Sol-Team, with the last update (PV SOL premium 2019 R10) I am having this error more frecuently and mor dramatic. I have already lost 2 projects with this error where I cant reenter to the projet and I had to do them again. I cant see more details about the error, just the picture that I have attached. Is there a configuration to solve it or some parameters to avoid it? Thank you! Report
July 10, 20197 yr comment_2735 Hello FeRm00, Could you send me the project file where this error occurs? Kind regards, Marcel Report
January 6, 20215 yr comment_4871 I have a same problem. ıs there a solution for this error? thank you Report
January 8, 20215 yr comment_4880 Dear Gianni, the problem that was reported was from PV*SOL premium 2019 R10. The most current version of our software is PV*SOL premium 2021 R3. Please consider updating, as there are a lot of bugfixes and new features. https://valentin-software.com/en/products/pvsol-premium/ Kind regards, Martin Report
March 30, 20215 yr comment_5229 Hi PV Sol-Team, I have the same problem, even I have PV*SOL premium 2021. Mostly it happening when I want to continue work on same project / or make modification/ or make a copy. Hope for your help. Best regards, Ola Report
March 30, 20215 yr comment_5231 Hi Ola, could you send the project file via private message here in the forum? Best regards, Frederik Report
June 17, 20215 yr comment_5645 Hi! I also get the same problem as Ola above. Everytime I try to save the file, or configure the modules I get a message saying an error has occurred. Best regards, Helena Report
