AJ Alriyadh Posted November 23, 2018 Report Posted November 23, 2018 Hello, When designing in 3d mode, the menu bar where objects, such as walls, trees, ...etc, can be added doesn't appear and cannot be configured to do so. I have tried all possible scaling options (e.g. change the monitor, adjusting the scale of apps) without success. I have contacted the technical and sales teams, but no response. I also asked other users and they reported the same problem. We own a solar system design company in the middle east and trying to use PV*SOL as the main designing software. The software seems the most promising platform for solar design out there, but with such a disappointing issue and response, we are currently looking for alternatives. We really hope this would improve. Please check the attachment below for more information. Best, Quote
developer_mh Posted November 26, 2018 Report Posted November 26, 2018 Hello AJ Alriyadh, thank you for reporting this bug. We already know of it, but unfortunately we cannot reproduce the error so at the moment we can't find the source of the error. But you can try the following workaroud, which helps most of our customers who experience the same problem: Install the newest version of PV*SOL premium (right now it is 2018 R3) Run it once and close it, so that you find the file PVSOL.ini in this folder: C:\Users\USERNAME\Documents\Valentin EnergieSoftware\PVSOL premium 2019\PVSOL.ini Open it in a text editor and search for the element <MainPagerWider>0</MainPagerWider> Change it to <MainPagerWider>-1</MainPagerWider> and save the file Start PV*SOL premium Could you tell us if your menu bars are visible now in the 3D visualisation? Thanks a lot and sorry for the inconvenience caused, Martin Quote
ricardoapupo@hotmail.com Posted November 26, 2018 Report Posted November 26, 2018 Hi Support Team, I´m facing the same behaviou with my PVSOL 2019 Premiuin (R2). Please find attached the file sharing rhe information. I have downloaded and intalled de 2019 (R3) and the problem remains. Let me know any further action that could be done in order to fix it. Ricardo Quote
developer_mh Posted November 27, 2018 Report Posted November 27, 2018 Hey Ricardo, have you tried the workaround mentioned above? Does it help you? Kind regards, Martin Quote
ricardoapupo@hotmail.com Posted November 27, 2018 Report Posted November 27, 2018 Hi Martin, I've performed the suggested workaround action and it seems to work so far. Thanks Ricardo Quote
Alexclavijon Posted May 18, 2019 Report Posted May 18, 2019 what if i don't have the text <MainPagerWider>-1</MainPagerWider>, or maybe i am opening the wrong file? Thanks for answering. Quote
developer_mm Posted May 20, 2019 Report Posted May 20, 2019 Hello Alexclavijon, Yeah, that is the wrong file. You have looked at the installation directory/folder, instead you have to take the file under your user directory under "C:\Users\YourUserName\Documents\Valentin EnergieSoftware\PVSOL premium 2019\PVSOL.ini". Kind regards, Marcel Quote
Fabian Licznerski Posted November 29, 2019 Report Posted November 29, 2019 Good Day, I've been having the same problem, but the workaround seems to have made the program at least usable. Best Wishes, Fabian Quote
keirm Posted December 4, 2020 Report Posted December 4, 2020 Im having the same problem with a version downloaded Premium 2021 <MainPagerWider>-1</MainPagerWider> already exists in the ini file Best Regards, Keir Quote
keirm Posted December 4, 2020 Report Posted December 4, 2020 Also there is a bug when trying to switch between map providers. There is also a bug on the first 3d visualization screen, there is a menu off to the right that I cant see, if I click the arrow to open the text opens off to the right of my screen. Quote
developer_mh Posted December 7, 2020 Report Posted December 7, 2020 Hi keirm, did you try to apply this work-around here: Quote Also there is a bug when trying to switch between map providers. This should be fixed in the new release, PV*SOL premium 2021 R3. Quote There is also a bug on the first 3d visualization screen, there is a menu off to the right that I cant see, if I click the arrow to open the text opens off to the right of my screen. Could you provide a screenshot, please? Also, does this behaviour disappear when you apply the above mentioned work-around? Hope that helps, kind regards, Martin Quote
