Can't place a cable node on a flat roof
I often have problems placing a cable node on flat roofs (small and big installations) but i have no clue why.
The symbol for placement remains grey so I can't select it and cable plan can't be created.
Can you explain where it goes wrong?
  • 1 month later...
Hi!
I have tried to do a cable node on a module coverage installation but that does not work either.
When will cable node work on flat roofs and installations not mounted directly on a roof?
Hi Patrik,
if you placed your modules directly via Module Coverage and confgured them with an inverter you should be able to use the cabling feature, regardless of whether it is a flat roof, an open area or another building.
Unfortunately I can't say when it will be possible to use the cable feature for module mountings.
Marcel
Why is this not available? What is the problem? I dont see what the big deal is? 90% of all of the systems ar mounted on one way or another so this should be included as soon as possible in the 3D design.
Hi Patrik,
I can understand the displeasure. Unfortunately, there are many feature requests in different program areas that we have to consider. In addition, we have to restructure PV*SOL internally to be able to offer regular features in the future.
I will make it clear during feature planning that this is a very requested feature. If this will also be implemented for the next product version is a different decision process.
Sorry very much for that, but nevertheless I wish you a Merry Christmas soon :)
