Caio Monteiro Posted October 25, 2018 Report Posted October 25, 2018 Hi everyone, I´m trying to use the 3d modeling tool on PV SOL 2018, but it just don´t shows its icons maybe because of the resolution of my screen, but i´ve tried every resolution since 1280 x 720 px to 3840 x 2160 px but nothing worked. PS :Few weeks ago everithing was working fine. OS: WIndows 10 Regards, Cesar Monteiro Quote
developer_mh Posted October 26, 2018 Report Posted October 26, 2018 Hi Cesar, we had several customers with this bug. Unfortunately we still haven't identied the real source of the problem. But in PV*SOL premium 2018 R10 we added some UI enhancements that should minimize the impact of this bug. Which version are you using. And when you say " Few weeks ago everithing was working fine. " could you tell us what happened in the meanwhile? Did you update PV*SOL, oder Windows? Or some graphics drivers perhaps? Every information is helpful! Thanks a lot, kind regards, Martin Quote
Caio Monteiro Posted October 26, 2018 Author Report Posted October 26, 2018 Hi Martin, thanks for the prompt reply. It's the same OS and the same laptop. I always keep both Windows and PVSOL updated. Do you have any idea to solve this issue? An older version of PVSOL? PVSOLpremium.exe 2018.10.43.0 31/8/2018 17:15 PVSOL.sdf 5.0.3 23/10/2018 10:31 EnergySoftware.Common.BinFiles.dll 2.0.1.1 15/11/2017 16:33 EnergySoftware.Common.CAD.dll 2018.10.43 31/8/2018 17:08 EnergySoftware.Common.dll 2018.10.43.0 31/8/2018 17:09 EnergySoftware.Common.Forms.dll 2018.10.43.0 31/8/2018 17:09 EnergySoftware.Common.UnitConversion.dll 2.0.4.27808 31/8/2018 17:10 EnergySoftware.Lm.dll 1.3.0.35 7/6/2018 18:26 EnergySoftware.Lm.Net.dll 1.0.1.0 31/8/2018 17:10 EnergySoftware.MeteoSyn.Api.dll 4.0.146 31/8/2018 17:10 EnergySoftware.MeteoSyn.dll 4.0.146 31/8/2018 17:10 EnergySoftware.PV.AutomaticVs.dll 2018.10.43 31/8/2018 17:11 EnergySoftware.PV.Calculation.dll 2018.10.43.0 31/8/2018 17:11 EnergySoftware.PV.Contracts.dll 2018.10.43.0 31/8/2018 17:11 EnergySoftware.PV.DB.dll 2018.10.43.0 31/8/2018 17:11 EnergySoftware.PV.ResultLogger.dll 2018.10.43 31/8/2018 17:12 EnergySoftware.PV.Serialization.dll 2018.10.43 31/8/2018 17:12 EnergySoftware.PV.Serialization.XmlSerializers.dll 2018.10.43.0 31/8/2018 17:12 EnergySoftware.PV.Shared.dll 2018.10.43 31/8/2018 17:12 EnergySoftware.Simulation.Constants.dll 2.1.0.20844 31/8/2018 17:12 EnergySoftware.Simulation.dll 2.1.0.20844 31/8/2018 17:13 EnergySoftware.Simulation.Math.dll 1.0.2.0 31/8/2018 17:13 EnergySoftware.SimulationElectricalSystems.dll 2.1.0.20844 31/8/2018 17:13 EnergySoftware.SimulationGeneral.dll 2.1.0.20844 31/8/2018 17:13 EnergySoftware.SimulationLibrary.dll 2.1.0.20844 31/8/2018 17:13 assimp_pvsol.dll 4.0.1.1 31/8/2018 17:07 Pvsoldll.dll 5.5.2.290 31/8/2018 17:07 Visual3D.dll 4.0.1.721 31/8/2018 17:07 Sistema operacional: Microsoft Windows NT 6.2.9200.0 .Net Framework Version: 4.0.30319.42000 Quote
Caio Monteiro Posted October 29, 2018 Author Report Posted October 29, 2018 Martin, I´ve downgraded to the version: "PVSOLpremium.exe 2017.9.0.0 19/4/2017 14:17" Now it´s working fine again. Please let me know when this error is going to be corrected on newer versions. BR, Quote
developer_mh Posted November 6, 2018 Report Posted November 6, 2018 Hi Caio, perhaps you could try the following: Install the newest version of PV*SOL premium (right now it is 2018 R10, soon it will be 2019 R1) Run it once and close it, so that you find the file PVSOL.ini in this folder: C:\Users\USERNAME\Documents\Valentin EnergieSoftware\PVSOL premium 2019\PVSOL.ini Open it in a text editor and search for the element <MainPagerWider>0</MainPagerWider> Change it to <MainPagerWider>-1</MainPagerWider> and save the file Start PV*SOL premium Could you tell us if your menu bars are visible now in the 3D visualisation? Thanks a lot and sorry for the inconvenience caused, Martin Quote
Juliana González Posted July 31, 2021 Report Posted July 31, 2021 Hola, trabajé en una simulación y funcionó correctamente, luego quise editar el modelo 3d para visualizarlo y me sale ventana de error que no me. Permite acceder al mldelo 3D Hi! I was working in a simulation I done perfectly, but 5 hours after I opened and It appears with and error in the 3D editor. Thanks Quote
developer_mh Posted August 2, 2021 Report Posted August 2, 2021 Hi Juliana, the reason for the error is that the grid voltage is set to 254.03 V. Our 3D environment can't handle that. Change it to 254 V (or any other value) and it should work. And of course you are free to contact us on any channel that you prefer (mail, forum, phone), but please consider that it might cause double effort for us if you contact us on two channels simultaneously. Kind regards, Martin Quote
Thomas_10hoch4 Posted October 25, 2021 Report Posted October 25, 2021 On 10/26/2018 at 10:18 AM, developer_mh said: Hi Cesar, we had several customers with this bug. Unfortunately we still haven't identied the real source of the problem. But in PV*SOL premium 2018 R10 we added some UI enhancements that should minimize the impact of this bug. Which version are you using. And when you say " Few weeks ago everithing was working fine. " could you tell us what happened in the meanwhile? Did you update PV*SOL, oder Windows? Or some graphics drivers perhaps? Every information is helpful! Thanks a lot, kind regards, Martin I had the same problem, but in with the 2021 version! I solve it when I start PVSOL with a monitor scale of 175%. When I'm in the 3D simulation, I turn it back to normal 100%. 1) Put your monitor scale on 175% (The monitor where PVSOL opens) 2) Start PVSOL 3) Enter 3D simulation 4) Open Windows Display settings and turn it back to normal scale Hope I was able to help anyone! 1 Quote
Infinitech Posted August 1, 2022 Report Posted August 1, 2022 Same isseu here... laptop - 1920 x1200 scale 125% monitor - 1920 x 1080 scale 100% Both the solution from Thomas_10hoch4 and the Change <MainPagerWider>0</MainPagerWider> to -1 not work... Windows 11, PVSol Premium 2022 R6 edit: I used the Windows troubleshooter. Introduced changes: screen settings: scaling to a higher DPI value but now I have a problem that every time I start program the ribbon icons are "big" (as in the attachment) even if I uncheck 'Enlarge main button bar' after close and open pvsol it stay checked also i can't set back <MainPagerWider>-1</MainPagerWider> to 0. edit2: i change resolution of laptop to 1680:1050 and scale to 100% <MainPagerWider>-1</MainPagerWider> and it looks like attachment pvsol2. a bit better but far from ideal... Maybe should make change in some of this settings: <GUI> <SideBarWidth>250</SideBarWidth> <SideBarOpen>-1</SideBarOpen> <SortTvStacked>0</SortTvStacked> <HauptDlgFullScreen>-1</HauptDlgFullScreen> <HauptDlgWidth>1936</HauptDlgWidth> <HauptDlgHeight>1048</HauptDlgHeight> <HauptDlgLeft>1672</HauptDlgLeft> <HauptDlgTop>-8</HauptDlgTop> <SchattenAnAus>-1</SchattenAnAus> <MainPagerWider>-1</MainPagerWider> <MeshReducingNew>-1</MeshReducingNew> </GUI> Quote
developer_mh Posted August 4, 2022 Report Posted August 4, 2022 Hi Infinitech, it looks like the scaling override behaviour is not set to the default value. See this thread here: Also be sure not to use the Windows 11 from the release preview channel. Kind regards, Martin Quote
Infinitech Posted August 4, 2022 Report Posted August 4, 2022 Options > General > Enlarge main button bar is chekced Regardless of whether the High DPI Override (PVSOLpremium.exe and ValentinSoftware.PV.Desktop.Wow6432.exe) option is checked or unchecked, it does not solve the problem. Windows 11 Home 21H2 Quote
developer_fw Posted August 5, 2022 Report Posted August 5, 2022 Hi Infinitech, thank you for this valuable information. I forwarded this issue to our 3D developer, since it sounds like something that is new with Windows 11. Best regards, Frederik Quote
Infinitech Posted August 22, 2022 Report Posted August 22, 2022 On 8/5/2022 at 3:51 PM, developer_fw said: Hi Infinitech, thank you for this valuable information. I forwarded this issue to our 3D developer, since it sounds like something that is new with Windows 11. Best regards, Frederik Hi, is there any info about this issue? Quote
developer_fw Posted August 24, 2022 Report Posted August 24, 2022 Hi Infinitech, we did several things: We double checked on machines running Windows 11 with a high resolution plus highDPI scaling We checked if there was a higher number of people reporting issues On our machines we could not reproduce this graphical issue. So far we did not receive tickets regarding recent high DPI problems. Albeit your configuration On 8/1/2022 at 10:56 AM, Infinitech said: laptop - 1920 x1200 scale 125% monitor - 1920 x 1080 scale 100% Both the solution from Thomas_10hoch4 and the Change <MainPagerWider>0</MainPagerWider> to -1 not work... Windows 11, PVSol Premium 2022 R6 is there any special graphic configuration? I am sorry you are confronted with these issues, I'll initiate another discussion here. Kind regards, Frederik Quote
Infinitech Posted September 8, 2022 Report Posted September 8, 2022 Hi, I don't have any specific additional configurations. Intel® Core™ i5-12450H Intel® UHD Graphics Windows 11 21H2 Other people also have this problem: https://forum.valentin-software.com/topic/3407-editing-options-error/?do=findComment&comment=8474 Quote
developer_fw Posted September 13, 2022 Report Posted September 13, 2022 Hi Infinitech, please get in contact with our support team: hotline@valentin-software.com Kind regards, Frederik Quote
