Stadiums Roof Truss
Hi,
How can I capture the shading for a roof truss on a stadium roof?
Is there any tips out there?
Thanks
Hello CarlSEL
You could import a 3D model of the truss and simulate it.
In case you do know the typical configuration which might get repeated for the whole roof, you could simulate a part of your project in different situations to get a percentage for an estimation of the losses.
Kind regards
Hello CarlSEL
1 hour ago, CarlSEL said:
what is the process for copying a truss?
Could you specify what you are trying to achieve with PV*SOL?
Unfortunately PV*SOL is no 3D CAD software, which makes constructing delicate objects hard to impossible.
In such cases we recommend using external software before importing the needed 3D objects into PV*SOL for shading analysis.
Kind regards
Hello CarlSEL
Something like this cannot be created within PV*SOL. Have a look into open 3D models, get in contact with the stadium since they might have plans. Or even better: Contact the company which created the truss.
Overall it looks like it might not be worth it to even consider PV. That is why I would recommend creating one part that looks alike to get an estimation value for one section of that truss.
Kind regards
  • 1 month later...
On 8/1/2023 at 2:41 PM, developer_fw said:
Hello CarlSEL
Kind regards
Hi, what software would you recommend to create the 3D software? Also, what software is compatible?
Thanks
  • 2 weeks later...
