April 12, 20233 yr comment_13117 Hey there, This is the second time that this issue happens to me. Import the image in Photoplan, design the system and once I close the Photoplan window the little image in PVSOL gets grey. At first I thought it was only that little image but if I enter back in photoplan I see something like this. I "solved" it exporting the picture once I created the design and then replacing the grey image in the report with the good one that I exported before. Any ideas? Thanks in advance Report
April 17, 20233 yr comment_13151 Hello Esteban Unfortunately I never heard of this issue before. I passed this to our support team and created a ticket. Could this happen since you updated your Windows OS? Could you specify a vague date where updates did take place probably? Thank you for further information and kind regards! Frederik Report
April 18, 20233 yr Author comment_13161 Hi Frederik, Mmm honestly I don't think it has to do with the Windows update. This is the second time that happens to me and I've done quite a few projects. I believe that maybe has to do with the image characteristics (probably size or something like that) I'll run some test and see if I find the solution. It was just to know if this was a known issue. In other order of things, I'm facing another issue. I'll post it here but let me know if I have to create a new thread. Second or third time that this happens to me. When I change some characteristics of the projects, the simulation results and report are not shown. The first time was when I activated or deactivated the 3D view, now is depending on the model of batterie that I choose. Any idea? Report
April 25, 20233 yr comment_13228 Hi Esteban On 4/18/2023 at 5:00 AM, Esteban said: Any idea? This sounds extremely strange. Could you send two files of a project so I can have a look into it? The simulation results are not shown after a re-simulation took place in order to respect the changed parameters? Thank you in advance and kind regards Frederik Report
June 8, 20233 yr Author comment_13605 On 4/25/2023 at 10:51 AM, developer_fw said: Hi Esteban This sounds extremely strange. Could you send two files of a project so I can have a look into it? The simulation results are not shown after a re-simulation took place in order to respect the changed parameters? Thank you in advance and kind regards Frederik A little bit late but here's a file that does what I told you. If you change the battery (not use the Sungrow SBR 9.6 kWh) the report gets generated. Pretty strange. Let me know if you find a solution. Test.pvprj Report
June 9, 20233 yr comment_13611 Hi Esteban, I loaded the project file into my PV*SOL and it does simulate as it should. Then the report is generated as it should. Also if I change the battery system, everything works well. Could you provide your logfiles, please? You can find them here: C:\ProgramData\Valentin EnergieSoftware\log First, please reproduce the issue on your computer, then close PV*SOL and send us the file pvsolpremium.log from the above mentioned folder. You can send it here as a private message. Best regards, Martin Report
