Daniel Posted December 20, 2017 Report Posted December 20, 2017 Hi, Short question regarding the value in the software for CO2 savings, What it the value based upon? Best regards Daniel Quote
developer_mh Posted December 20, 2017 Report Posted December 20, 2017 Hi Daniel, this value refers to the current energy mix in the country where you design your PV system. In Germany, for example, we have an energy mix that produced ~ 530 g CO2 per kWh in 2016. This value is used to calculate the CO2 emissions that were avoided thanks to your PV system. Kind regards, Martin 1 Quote
Daniel Posted December 20, 2017 Author Report Posted December 20, 2017 Hi Martin and thanks for your swift answer. So in my case that will mean that the value refers to the current energy min in Sweden. Where is this value collected? Where do you get the input from? Best Regards, Daniel Quote
developer_mh Posted December 20, 2017 Report Posted December 20, 2017 Hi again, yes, you would have to find out the specific co2 emission for Sweden, as up-to-date as possible. Perhaps the Swedish energy ministry publishes such data? On Wikipedia I found that in 2013 the electricity consumption was 133.2 TWh, while the CO2 emissions were 37.5 Mt. This would equal to 282 g/kWh, but perhaps you'll find more recent information. Here's the Wikipedia page: https://en.wikipedia.org/wiki/Energy_in_Sweden Kind regards, Martin Quote
obrvaner Posted April 1, 2022 Report Posted April 1, 2022 Hello everyone, I will hijack this thread as to avoid creating a new one. Based on the CO2kWh from the simResults, how do you calculate the actual CO2 emissions avoided that is shown in the report? I have tried multiplying it with several kWh/Year fields, starting with Own Consumption, but I am unable to arrive at the value in the report. What is the formula here? CO2kWh * ? Thanks in advance Quote
Jimmy Posted April 2, 2022 Report Posted April 2, 2022 Hi obrvaner, Yeah, the calculation is just as simple as g/kWh and you have to input that yourself based on your region and and LCA for the system. You can change it here: And I just want to add, in regards to what Martin said above about how dirty our electricity in Sweden is that the calculation is wrong because those are our total energy emissions calculated on electricity production. And electricity only stands for about 9% of our emissions. We're about 30g/kWh, second cleanest electricity in Europe I believe. Which, coupled with the most reliable LCA I've read (assuming that the panels are made in China) doesn't really guarantee that solar in Sweden is a net positive for the climate. I don't tell my costumers this as they're not really after the environmental benefits but rather the economical and if they want to feel like they're doing the climate a great service at the same time I'm not going to burst their bubble. Quote
obrvaner Posted April 3, 2022 Report Posted April 3, 2022 Hello Jimmy, Thank you for your response. My question is which value(s) need to be multiplied with 470 (or whichever value is set for CO2 saving) to get the highlighted result bellow. To clear things up, I am using the simResults.xml to generate the same report and can not figure out the formula. Quote
Jimmy Posted April 4, 2022 Report Posted April 4, 2022 I think it should be the "PV Generator Energy (AC Grid)" with a slight rounding error, at least that's what I get. But if you're using 470g/kWh I can't make sense of your numbers. Quote
Sofie Posted November 20, 2023 Report Posted November 20, 2023 From what I know, the On 4/1/2022 at 10:49 PM, obrvaner said: Hello everyone, I will hijack this thread as to avoid creating a new one. Based on the CO2kWh from the simResults, how do you calculate the actual CO2 emissions avoided that is shown in the report? I have tried multiplying it with several kWh/Year fields, starting with Own Consumption, but I am unable to arrive at the value in the report. What is the formula here? CO2kWh * ? Thanks in advance From what I know, the formula is this: CO2 emissions avoided = [PV Generator Energy (AC Grid) – Standby Consumption (Inverters)] x Specific CO2 savings through the use of PV energy The used values for the “Specific CO2 savings through the use of PV energy” can be found under “Options” > Project Options” > “AC Mains”. Of course, the value is more valid for Germany, as it represents the German electricity mix. It comes from the Federal Environment Agency (Umweltbundesamt). If necessary, you would have to enter a value there that would be valid for Denmark. But we unfortunately do not know these values. Quote
Sofie Posted November 20, 2023 Report Posted November 20, 2023 On 12/20/2017 at 1:34 PM, developer_mh said: Hi again, yes, you would have to find out the specific co2 emission for Sweden, as up-to-date as possible. Perhaps the Swedish energy ministry publishes such data? On Wikipedia I found that in 2013 the electricity consumption was 133.2 TWh, while the CO2 emissions were 37.5 Mt. This would equal to 282 g/kWh, but perhaps you'll find more recent information. Here's the Wikipedia page: https://en.wikipedia.org/wiki/Energy_in_Sweden Kind regards, Martin How do you go from the 37,5Mt to 282 g/kWh? Quote
developer_mh Posted November 20, 2023 Report Posted November 20, 2023 Dear all, I'd like to share an interesting website I found recently where you can look up the specific CO2 emissions per country on a map: https://ourworldindata.org/grapher/carbon-intensity-electricity 40 minutes ago, Sofie said: How do you go from the 37,5Mt to 282 g/kWh? This was really a very rough estimate, by just diving the CO2 emissions by the electricity consumption, 37.5 Mt / 133.2 TWh = 282 g/kWh. This calculus does take into account a whole bunch of factors and actually we should forget that I even did that calculation We should look it up on the above website instead. Kind regards, Martin Quote
developer_fw Posted November 20, 2023 Report Posted November 20, 2023 Hej for more information on carbon footprints per kWh there is the app Electricity Maps. https://app.electricitymaps.com/map It looks like this and you could get aggregated data for several historical years. Kind regards Frederik Quote
