Vishnu Posted July 27, 2022 Report Posted July 27, 2022 I have reinstalled my PVSol and ever since the editing options size has reduced and above all, no matte on which section I am, I see the same editing options. Could you please help me solve this issue. Thank you Quote
developer_fw Posted July 27, 2022 Report Posted July 27, 2022 Hi Vishnu, you might try the following: Options > General > Enlarge main button bar Does this solve your problem? Kind regards, Frederik Quote
Vishnu Posted July 27, 2022 Author Report Posted July 27, 2022 Hello Frederik, Thank you for your response. It partially solved it. I can now see the main button bar but it is still with relatively small buttons. Is it possible to make it more comfortable like I see it in your screenshot? My PVSol used to be like that before I reinstalled it Cheers, vishnu Quote
Vishnu Posted July 29, 2022 Author Report Posted July 29, 2022 Hallo again, The problem still exists. In addition to the main menu bar, the information bar at the bottom of the screen is too small to read. And it sometimes get really uncomfortable as the mouse clicks just do not work. I had to go to a different window and come back to PVSol. I tries reinstalling the software but it did not help. Quote
developer_mh Posted July 29, 2022 Report Posted July 29, 2022 Hi Vishnu, you can try changing the High DPI override behavior as described here: Also apply these settings to ValentinSoftware.PV.Desktop.Wow6432.exe Kind regards, Martin Quote
Vishnu Posted July 29, 2022 Author Report Posted July 29, 2022 Moin Martin, Thank you for your reply. I check your suggestion to uncheck the High DPI Override and it's already unchecked on my laptop. So tried by checking the check box and surprisingly now the menu bar seems normal. ^^ Do you think I can leave this check box checked? Cheers, Vishnu Quote
developer_mh Posted July 29, 2022 Report Posted July 29, 2022 5 hours ago, Vishnu said: Do you think I can leave this check box checked? Sure, whatever works on your machine Quote
Lutz Posted August 28, 2022 Report Posted August 28, 2022 Hi team, unfortunaltly I experienced the same problem on my W11 desktop. I tried everythin mentioned above, settings related to High DPI are not solving the prob, independet from what combination of settings I use, but nothing helps. With this problem I can't use PV*SOL on my W11 machine with a 4K monitor. I really would appreciate it if could support me with a fast and reliable solution... Many Thx and brgds Lutz 1 Quote
Lutz Posted September 12, 2022 Report Posted September 12, 2022 Dear team, unfortunately we didn't get any reaction on this problem. Do you had the chance to dive in this issue and do you have a solution for us by hand? I would appreciate some reaction from your side about this blocking issue... Thx and brgds Lutz Quote
developer_fw Posted September 13, 2022 Report Posted September 13, 2022 Hi Lutz, please get in contact with our support team: hotline@valentin-software.com Kind regards, Frederik Quote
