Editing options error
I have reinstalled my PVSol and ever since the editing options size has reduced and above all, no matte on which section I am, I see the same editing options.
Could you please help me solve this issue. Thank you
Hello Frederik,
Thank you for your response. It partially solved it. I can now see the main button bar but it is still with relatively small buttons.
Is it possible to make it more comfortable like I see it in your screenshot?
My PVSol used to be like that before I reinstalled it
Cheers,
vishnu
Hallo again,
The problem still exists. In addition to the main menu bar, the information bar at the bottom of the screen is too small to read.
And it sometimes get really uncomfortable as the mouse clicks just do not work. I had to go to a different window and come back to PVSol.
I tries reinstalling the software but it did not help.
Moin Martin,
Thank you for your reply.
I check your suggestion to uncheck the High DPI Override and it's already unchecked on my laptop.
So tried by checking the check box and surprisingly now the menu bar seems normal. ^^ ;)
Do you think I can leave this check box checked?
Cheers,
Vishnu
  • 5 weeks later...
Hi team,
unfortunaltly I experienced the same problem on my W11 desktop. I tried everythin mentioned above, settings related to High DPI are not solving the prob, independet from what combination of settings I use, but nothing helps. With this problem I can't use PV*SOL on my W11 machine with a 4K monitor. I really would appreciate it if could support me with a fast and reliable solution...
Many Thx and brgds
Lutz
  • 2 weeks later...
Dear team,
unfortunately we didn't get any reaction on this problem. Do you had the chance to dive in this issue and do you have a solution for us by hand? I would appreciate some reaction from your side about this blocking issue...
Thx and brgds
Lutz
