Vishnu Posted July 19, 2021 Report Posted July 19, 2021 Heya Team, I observed on the inverter config page that the module surface orientation is different in the new PVSol version. As you can see in the image, I have two module surfaces facing Nord-west and Nord-ost but the inverter config shows only Nord-west Is this something that has actually been changed in the new version or is it a bug? Thank you! Quote
developer_mh Posted July 20, 2021 Report Posted July 20, 2021 Hi Vishnu, thank you for reporting this. Could you provide the project file please? I quickly checked it, and it seems to work as expected: Kind regards, Martin Quote
Trond Posted July 30, 2021 Report Posted July 30, 2021 (edited) We experience the same issue in our company. This is a bug that has come quite recently. And it goes for all users File to Valentin.pvprj It looks like the problem occurs when drawing a building from polygon. When adding building from menu, it works as expected. Edited July 30, 2021 by Trond added info Quote
Trond Posted July 30, 2021 Report Posted July 30, 2021 This fault is actually not consistent either.... On this file I drew one more polygon and extracted building. Same procedure as the first; but now it worked.  File to Valentin_2.pvprj Quote
developer_mh Posted July 30, 2021 Report Posted July 30, 2021 Dear all, this is a bug that was introduced with the latest version, PV*SOL premium 2021 R7. It will be fixed in the upcoming bugfix release, R8. It affects mounted PV systems with various orientations, like east-west systems, on flat roofs. We are very sorry for the inconvenience caused and try to publish the bugfix release as soon as possible. Kind regards, Martin Quote
