Module surface orientation on Inverter Config page
Heya Team,
I observed on the inverter config page that the module surface orientation is different in the new PVSol version.
As you can see in the image, I have two module surfaces facing Nord-west and Nord-ost but the inverter config shows only Nord-west
Is this something that has actually been changed in the new version or is it a bug?
Thank you!
  • 2 weeks later...
We experience the same issue in our company. This is a bug that has come quite recently. And it goes for all users
File to Valentin.pvprj
It looks like the problem occurs when drawing a building from polygon. When adding building from menu, it works as expected.
Edited by Trond
added info
This fault is actually not consistent either.... On this file I drew one more polygon and extracted building. Same procedure as the first; but now it worked.
File to Valentin_2.pvprj
Dear all,
this is a bug that was introduced with the latest version, PV*SOL premium 2021 R7. It will be fixed in the upcoming bugfix release, R8. It affects mounted PV systems with various orientations, like east-west systems, on flat roofs. We are very sorry for the inconvenience caused and try to publish the bugfix release as soon as possible.
