patrik k Posted May 6, 2021 Report Posted May 6, 2021 When i choose a known black panel in photoplan, it doesnt show up as black. I can only choose black frame. Is it possible to fix the colour to match the panels? Or make it possible to Chang  the colour of the panel like in the 3D configuration? Quote
developer_fw Posted May 7, 2021 Report Posted May 7, 2021 Hi patrik k, this is not possible with Photo Plan. There is a workaround, which takes about 5 minutes using GIMP, an open source bitmap manupulation program https://www.gimp.org/ Open the picture Use the "Free Select"-Tool for selecting the module area Via Colors > Saturation set the saturation of the selected area to 0.0. Export the picture with the changes you made. Best regards, Frederik Quote
patrik k Posted May 7, 2021 Author Report Posted May 7, 2021 I tried to set the saturation to 0 but only get this colour? They only get grey... Quote
developer_fw Posted May 10, 2021 Report Posted May 10, 2021 Hi patrik k, sorry for the late response. Could you send me the "original" picture from PhotoPlan here or via private message? Thank you in advance. Best regards, Frederik Quote
patrik k Posted May 11, 2021 Author Report Posted May 11, 2021 On 5/10/2021 at 10:27 AM, developer_fw said: Hi patrik k, sorry for the late response. Could you send me the "original" picture from PhotoPlan here or via private message? Thank you in advance. Best regards, Frederik  Quote
patrik k Posted May 11, 2021 Author Report Posted May 11, 2021 You can change the colour of the frames in PV sol, is it much work for you to also implement it on the colur it self Quote
developer_fw Posted May 11, 2021 Report Posted May 11, 2021 Hi patrik k, the problem here is, that PhotoPlan is external software that was bought by us a long time ago. Due to the age there is no maintenance and neither do we have the source code nor do we have permission to change anything. This is why my standard answers refer to bitmap manipulating. I tried a bit, there is no recipe, but with brightness, contrast and some colour variation, you could achieve this: Best regards, Frederik Quote
patrik k Posted May 12, 2021 Author Report Posted May 12, 2021 @frederikdo you think it is possible for me to get in contact with the company that made photoplan to perhaps make this change that owns and knows the code? I understand that there would be a cost for changing this. but since we sell 90% black panels it would make a lot of differnence! Quote
developer_fw Posted May 17, 2021 Report Posted May 17, 2021 Hi patrik k, the contact to the company is http://www.sbs-softwaresysteme.de/site/303/Kontakt.aspx Best regards, Frederik Quote
Josua Posted September 15 Report Posted September 15 @patrik k I'm having the same issue. Do you heard anything new from PhotoPlan or this Company? Quote
hotline_oh Posted September 16 Report Posted September 16 Dear Josua, Thank you for your inquiry. Photo Plan has been revised. First, select a PV module with black cells in PV*SOL, then select the texture with a black backsheet and frame in the lower right corner of Photo Plan. Quote
