April 26, 20215 yr comment_5340 Hello! I have created climate data for new locations many times in the past, always without any issue at all. But today I got the error text "Unable to generate climate data." multiple times for some locations, some others work. Any idea why that could be? Any workarounds? Cheers, Frido Report
April 26, 20215 yr comment_5343 Hi Frido, could you send the MeteoSyn Logfile via private message here in the forum? You can open the logfile folder via There should be files for MeteoSyn and pvsolpremium. Thank you in advance and best regards, Frederik Report
April 28, 20215 yr Author comment_5355 Hi Frederik, thanks for the quick reply. I'd be happy to share the file with you, but unfortunately there is no such file in this directory. See screenshot attached. As a work around, I have used climate data that I have created earlier from a place really close. It is absolutely fine results wise, but it would be nice for the client to see that we used their exact location. And also, I would like to know what to do should this problem occur with a different location (where I do not have existing climate data from a site close by already) in the future. Let me know if there is anything else I can do to assist troubleshooting. Cheers, Frido Report
April 29, 20215 yr comment_5363 Hi Frido, OK. Might it be possible to send me the file which you are trying to import via private message? Sometimes it is just the formatting of the input files. Please also have a look at this thread: Best regards, Frederik Report
May 3, 20215 yr Author comment_5373 Hi Frederik, sorry if I have not communicated this clearly: I am not trying to import climate data. I am trying to generate climate data using the MeteoSyn. So there is no file importing going on on my side. Cheers, Frido Report
May 3, 20215 yr comment_5382 Hi Frido, ah OK, my bad. Might you be so kind and send me the PVSOLpremium.log via private message? I tried to reproduce this bug but were not successful so far. Thanks in advance and best regards, Frederik Report
May 10, 20215 yr Author comment_5418 Hi! Just tried it again to make sur it still happend after the updated to 2021 R5 - it does. Sending you the log file asap. Cheers, Frido Report
