Hi Muhammad,
like timgreen said, the best way to go is to model it in another 3D application like Sketchup and import it then. A canopy like this is not possible with the built-in 3D design tools of PV*SOL.
  • Like 1
Hi Muhammad,
Is the fact that it does not have any walls that important to you?
For 95% of our projects, the only important thing is that the roof area is depicted correctly. So if I had to the depict the gas station seen in the picture I’d just go ahead with a flat roof building. I have found that it is much faster to do this way, & less prone to errors compared to using a 3D model. I try to avoid using 3D models whenever possible, as they have often caused issues.
Regards,
Frido
