Hello dear PVSol team,
I have a few questions! Which results are more precise when applying feed-in control. should the minute values be activated for <10 kWp PV systems?
Is there a specific diffuse radiation model that gives better results in this case?
Thanks in advance and best regards!
I am not sure about diffused radiation model but it is a good pratice to activate minute values when DC/AC ratio is above 1,15 and with batteries. It almost takes forever for the simulation ;) but still :)
  • Like 1
Hi K24,
as Vishnu pointed out, the activation of minute values is most of all important if you have sizing factors of above 115 %, or if you have battery systems or electrical appliances that are involved.
If your DC/AC ratio is about 1, and you just want to analyse the feed in, you might be well off with hourly values. But I would always recommend to compare the results at least once. Just simulate your PV system with hourly values, save the results somewehre, and then simulate the same system with one-minute values. Then you'll directly see the differences for your specific case.
Our recommendation for the diffuse model is Hofmann (disclaimer: that is me), but we don't recommend it just like that, we have scientific evidence that it performs best under nearly all conditions (especially when using one-minute resolution).
See more on diffuse irradiation models here:
https://help.valentin-software.com/pvsol/2020/calculation/irradiation/diffuse-irradiation/
  • Like 1
