Jordn Posted March 10, 2020 Report Posted March 10, 2020 Hi everyone, Regarding PV Sol 3D Design module textures I'd like to ask if there are greater variety of solar panel textures available for PV Sol. In particular something that looks similar to SunPower panels please. Anyone? Cheers! Quote
developer_mh Posted March 10, 2020 Report Posted March 10, 2020 Hi Jordn, there are some predefined module textures that are available in the 3D mode of PV*SOL. Go to the tab "Module Coverage" and right click on the modules, then choose "Change texture". There you can choose various cell textures and also the color of the backsheet and the framing. Let me know if this is sufficient for you. There is also another way to change the module texture, but this involves some tricky file handling and is an unofficial (and unsupported) approach. But yes, it is possible to integrate the texture you posted: Kind regards, Martin Quote
Mikecrypto Posted September 16, 2020 Report Posted September 16, 2020 On 3/10/2020 at 4:03 PM, developer_mh said: Hi Jordn, there are some predefined module textures that are available in the 3D mode of PV*SOL. Go to the tab "Module Coverage" and right click on the modules, then choose "Change texture". There you can choose various cell textures and also the color of the backsheet and the framing. Let me know if this is sufficient for you. There is also another way to change the module texture, but this involves some tricky file handling and is an unofficial (and unsupported) approach. But yes, it is possible to integrate the texture you posted: Kind regards, Martin Dear Martin, How can I manually change desing of PV-Sol modules like you say ,,but this involves some tricky file handling and is an unofficial". I want to change the structure and assign them permanently to a given model of photovoltaic modules Quote
Mikecrypto Posted September 22, 2020 Report Posted September 22, 2020 @developer_ahAre you still there? Can you help me? Quote
developer_mh Posted September 23, 2020 Report Posted September 23, 2020 Hi Mikecrypto, before I answer: I'd like to repeat that this is a hack and unsupported - and if someone asks: I didn't tell you Take the 3D project file where you want to change the textures make a copy of the file change the file extension from pvprj to zip. Use 7zip to extract all the content in the folder "Visu3D" there is an image file called "FrontTexturPvModul.jpg" replace this file with the texture that you want (must have same dimensions and bitness as the original) re-zip all the content that you previously unzipped change the extension from zip to pvprj open in PVSOL and see your texture on the modules in 3D Disclaimer: I wrote this from my rememberings, I didn't try it today. Hope that helps, kind regards, Martin Quote
Mikecrypto Posted September 24, 2020 Report Posted September 24, 2020 @developer_mh I send you PM (have some trouble) please check if you can Quote
