Ragy Posted February 22, 2020 Report Posted February 22, 2020 Hello, I downloaded PVSOL Premium 2020 from the website Solar Design Co and I bought the license, but doesn't complete the installation and giving me a/m error message in the title. Please see screenshot attached. What's the solution for this? Quote
developer_mh Posted February 24, 2020 Report Posted February 24, 2020 Hi Ragy, this error is unknown to me, but it looks like a system issue to me. "msxml3.dll" is a system library located in C:\Windows\System32\. Can you see it in your system? Also be sure that no other process is accessing the PVSOL.ini file here: "C:\Users\USERNAME\Documents\Valentin EnergieSoftware\PVSOL premium 2020\PVSOL.ini" or, if you install PV*SOL premium 2020 for the first time, check this file: "C:\Users\USERNAME\Documents\Valentin EnergieSoftware\PVSOL premium 2019\PVSOL.ini" Hope that helps to identify the problem. Kind regards, Martin Quote
Fredrik Posted November 26, 2021 Report Posted November 26, 2021 Hi, Just got this error message on the new release 2022/R2. Please help Runtime Error 146:4426 msxml3.dll:Accces is denied Running installation file as admin Quote
developer_mh Posted November 29, 2021 Report Posted November 29, 2021 Hi Fredrik, coudl you check if you have access to the following files: "C:\Users\USERNAME\Documents\Valentin EnergieSoftware\PVSOL premium 2021\PVSOL.ini" and "C:\Users\USERNAME\Documents\Valentin EnergieSoftware\PVSOL premium 2022\PVSOL.ini" as well as "C:\Users\USERNAME\Documents\Valentin EnergieSoftware\Installation.ini" Also check if these files are read-only or currently in use by another process or user. Hope that helps, kind regards, Martin Quote
Fredrik Posted November 29, 2021 Report Posted November 29, 2021 Hi, There were a read only on the 2022 PVSOL.ini. Disabled it and installation went smooth Thank you very much for the solution Quote
Afriyie Posted December 15, 2023 Report Posted December 15, 2023 Here's the error message when I try to install/update to PVSOL premium 2024 R2 Runtime Error (at 59:4679): msxml3.dll:Accces is denied Quote
developer_fw Posted December 18, 2023 Report Posted December 18, 2023 Hi Afriyie Could you ensure you do have necessary rights for the following files? Kind regards Frederik Quote
Afriyie Posted December 19, 2023 Report Posted December 19, 2023 Hi Frederik, Turns out the "...PVSOL premium 2024\PVSOL.ini" file was read only. I disabled it and have now successfully installed the R3 update. Thanks Afriyie 1 Quote
Afriyie Posted October 2, 2024 Report Posted October 2, 2024 @developer_fw im trying to update to PVSOL 2024 R8 here is the error message, even though read only for PVSOL.ini has been disabled. Quote
developer_mh Posted October 2, 2024 Report Posted October 2, 2024 Hey Afriyie, have you also checked this file? "C:\Users\USERNAME\Documents\Valentin EnergieSoftware\Installation.ini" Also, you can check all older PVSOL.ini files in each subfolder of "C:\Users\USERNAME\Documents\Valentin EnergieSoftware\" Hope that helps, kind regards, Martin Quote
ricksterzh Posted November 19 Report Posted November 19 I just deleted the Documents "Valentin Sorftware" folder (on OneDrive). Then the installation was finished properly. Cheers M. 1 Quote
