anees Posted July 27, 2024 Report Posted July 27, 2024 Hello can we configure pvsol such then solar should charge battery first and when power from solar is high then 1) it should charge battery first 2) if power is extra then that power cover load 3) if still power is left then that should goes to utility Quote
developer_fw Posted July 31, 2024 Report Posted July 31, 2024 Hello anees Unfortunately the energy flow cannot be changed. Since this is frequently asked I put this into debate again. Kind regards Frederik Quote
LFC Posted January 28 Report Posted January 28 Hola La opción de "Definir consumidores individuales" no funciona adecuadamente, puedes comprobarlo al definir periodos de operación por ejemplo solo una hora diaria o 10 horas diarias y el consumo anual y pico de carga se mantiene invariable. Deben revisar por que no varia según el tiempo elegido de funcionamiento ya que arroja resultados erróneos Quote
hotline_oh Posted February 2 Report Posted February 2 Dear LFC, Thank you for your inquiry. Please send your project file (*.pvprj) to hotline@valentin-software.com, so that we can take a closer look at it. Quote
