Leaned object in tilted terrain
Hi everyone!
I'm trying to place a structure (car park) in a tilted terrain, so that the structure assumes the inclination of the terrain but, it goes right throw it...
That car park also needs to be inclined towards west but it seem that PV Sol only allows me to lean an object in one axel. Is it true or there is another way of doing this?
Thanks
Luís
Hello Luís,
I guess you have three ways to get what you want.
(A) Place a "single saw tooth roof" on the building. Then you can change the orientation of this object as you like.
It would look like this:
(B) Create your own 3D modell and import it into PVSOL.
Further information can be found in our tutorial section in the forum.
(C) Shorten your map section and place an "open area" with a building
I hope this helps,
Kind regards and soon merry christmas,
Marcel
Hi Marcel,
Thanks for your help.
Unfortunately structures A) and C) aren't parallel to the terrain and that is what I need, maintaining a leaned roof with 6º.
Is it possible without having to model outside PVSOL?
Merry Christmas
Luís
  • 3 years later...
Hi Paco,
after creating a saw tooth roof, a right click onto the building opens the context menu which gives you the option to edit the orientation:
Best regards,
