omid Posted December 11, 2023 Report Posted December 11, 2023 Hi there, can someone explain to me the time controlled charging pleas, I am actually disappointed by this update, I thought it was only for battery charge from the grade, but it is actually stopping the battery to be charge by the PV too, which makes this a useless update in PVSol. We want the battery to be charge by the PV and if the PV generation is not enough to fully charge, we need to set a charging time for the off-peak times. Please let me know if this is possible. Thanks Omid Feed It Green Quote
developer_fw Posted December 12, 2023 Report Posted December 12, 2023 Hello omid 18 hours ago, omid said: I am actually disappointed by this update, I thought it was only for battery charge from the grade, but it is actually stopping the battery to be charge by the PV too, which makes this a useless update in PVSol. Could you please elaborate your statement? It is definitely possible to mix charging sources, otherwise it would have been indeed a downgrade. The example project "Battery System" is configured to avoid additional charging from the grid After activating time-controlled charging the charging by grid becomes bigger: 18 hours ago, omid said: Please let me know if this is possible. It is. Kind regards Frederik Quote
omid Posted December 13, 2023 Author Report Posted December 13, 2023 so, if you look at the attachments, when I activate the time controlled charging the system gives priority to that time ie.. I want the battery to be charge by PV first but if the battery in not charged 100% then I would like to set up a time like 00:00 to 04:00, so to do that I have to set the SOC target value to 100%, and when I chose this, the system charges the battery every night to 100% and at day time the battery is full. specially at summer months when the PV is high the battery should be only charged by PV but if you look at the results it is same always. please let me know if there is any better way. thanks Quote
developer_mo Posted December 19, 2023 Report Posted December 19, 2023 Hi omid, thanks for your question. Based on the scenario and the diagram I would assume following possibilities that causes the relatively low charging of the battery by the pv system: 1) the consumption takes almost all PV energy on the majority of the days 2) the battery gets less charging by PV energy because the it is full or almost full at the times when pv energy is available Of course, there could also be other reasons, such as the possibility that not all of the PV energy is available for charging the battery. For the scenario you're describing, I think it is plausible that the battery is mostly charged from grid because it is charged as much as possible every night. The Time-Controlled Charging in PV*Sol can only be set for the whole year and is not adaptable to changing seasons. So it is not possible to charge the battery to a lower SOC only in summer. If adaptability to season would help, I could forward it as a request to the developers. If the reason is still unclear, feel free to share the project file in the post or send it via private message in this forum. Kind regards Mikio Quote
Lee Taylor Posted September 23 Report Posted September 23 Hi We sell a lot of solar and batteries to UK Dairies and this issue of not being able to set the charging time for difference seasons is a massive hinderance in our simulations. We end up having to send out modelling which states the added benefit of it. But it would massive help to us to be able include this in our modelling. I appreciate this thread is a few years old but would be interested to know if this was ever raised to the developers? Kind Regards Lee Mole Energy Ltd Quote
hotline_oh Posted September 24 Report Posted September 24 Dear Lee Taylor, Thank you for your inquiry. Energy management in PV*SOL ensures that the battery is charged when there is a PV surplus, and PV*SOL is designed to optimise self-consumption. Other use cases where the battery is to be charged at night and discharged during the day (not to optimise self-consumption, but for other economic reasons) cannot yet be simulated well in PV*SOL. Our developers are aware of your use case and we are working on implementing it. 1 Quote
Lee Taylor Posted September 24 Report Posted September 24 Hi, Thanks that is fantastic news. Lee Quote
