unknown1990 Posted July 25, 2023 Report Posted July 25, 2023 Hello, so I have inverter that can be used in off grid mode (stand alone), Huawei L1 series. It cant be simulate in your software. And why it supposed to have two inverters if I want to use stand alone system. Thanks Quote
developer_fw Posted August 1, 2023 Report Posted August 1, 2023 Hello unknown1990 Sorry for the late answer. Could you elaborate your question? Kind regards Frederik Quote
ADAM Posted November 21, 2024 Report Posted November 21, 2024 Hi I have similar question Is there any chance to Add Huawei as a stand alone OffGrid inverter? Is there any chance to make commercial (300kW ) Offgrid in ur Software? Quote
hotline_oh Posted November 25, 2024 Report Posted November 25, 2024 Hello Adam, Yes, it is possible to design an offgrid 300 kW system in PV*SOL. Please let us know which Huawei battery inverter should be added to our database. If available, please send the data sheet to database@valentin-software.com, thank you! You can also create new data records for battery inverters yourself. We recommend copying an existing data record and overwriting the data. You can find instructions in our help section. Quote
