Hello,
so I have inverter that can be used in off grid mode (stand alone), Huawei L1 series. It cant be simulate in your software. And why it supposed to have two inverters if I want to use stand alone system.
Thanks
  • 1 year later...
Hi
I have similar question
Is there any chance to Add Huawei as a stand alone OffGrid inverter?
Is there any chance to make commercial (300kW )  Offgrid  in ur Software?
Hello Adam,
Yes, it is possible to design an offgrid 300 kW system in PV*SOL.
Please let us know which Huawei battery inverter should be added to our database. If available, please send the data sheet to database@valentin-software.com, thank you!
You can also create new data records for battery inverters yourself. We recommend copying an existing data record and overwriting the data. You can find instructions in our help section.
