April 24, 20233 yr comment_13216 Hi! I wonder how to, or if it is possible to, make and save a load profile (template) from one of the existing ones (under "load profiles / individual appliances". For example, I want to make a new load profile by changing some volumes from the already existing "Family house, Central Europe" (for instance to account for seasonal variations). Let's say I want to copy it, make some changes, and save it as a template with name "Family house, northern Europe". How can I do this? (As can be seen in the screenshot, I am not able to give new names: it only shows up with the same name, and "(copy)" as suffix). Report
April 26, 20233 yr comment_13247 Hello Torbjørn Heimvik On 4/24/2023 at 6:15 AM, Torbjørn Heimvik said: How can I do this? In the moment you do copy the profile via the context menu you will be able to put any name not existing in the database yet: I hope that helps. Kind regards Frederik Report
April 26, 20233 yr Author comment_13250 Hi, and thank you for your reply! I have tried this, without success. See below: I right click on "family house, central Europe" -> "copy" and then edit the profile as below. I also change name to "Test profile" and press "OK". But then, in the left side, it does not get the given name, only the old one with "(copy)" as suffix: That is. I cannot get the correct name? Best regards, Torbjørn Heimvik Report
April 26, 20233 yr comment_13252 Hi Torbjørn Heimvik Ouch. Hm, this looks like a bug we did not know of so far. Thank you for reporting it. Could you specify the exact version of PV*SOL? Which Windows OS are you using? Thank you in advance and kind regards Frederik Report
April 26, 20233 yr Author comment_13255 Hi again! I am currently using the demo (test version) of PV*SOL premium 2023 (R3), running on windows 11. Best regards, Torbjørn Heimvik Report
April 26, 20233 yr comment_13258 Hi Torbjørn Heimvik this is fixed in our upcoming release 2023 R4. Kind regards Frederik Report
April 26, 20233 yr Author comment_13259 Perfect. Thank you! Another thing: (perhaps for a different forum / thread), it does not seem possible to have "undo"/"redo" editing? Is this something that is planned for the future? This would be a must for us in future projects. Best regards, Torbjørn Heimvik Report
April 27, 20233 yr comment_13266 Hej Torbjørn Heimvik I am sorry to be that guy but I have to disappoint you. The current 3D does not offer this functionality and since a modern, Unity-based 3D environment with already working undo|redo history is in the making, we are not able to implement this feature for the existing codebase, I'm afraid. Kind regards Frederik Report
April 27, 20233 yr Author comment_13269 Hi! Ok, I understand. But in a future version of PV*SOL premium, this will be possible? In that case, when can we assume this update? Report
May 2, 20233 yr comment_13295 Hello Torbjørn Heimvik On 4/24/2023 at 6:15 AM, Torbjørn Heimvik said: How can I do this? (As can be seen in the screenshot, I am not able to give new names: it only shows up with the same name, and "(copy)" as suffix). The download for version 2023 R4 is now activated. Kind regards Frederik Report
