patrik k Posted May 18, 2018 Report Posted May 18, 2018 Im trying to create an irregular building that has a pithed roof,see attached pictyre, what is the easiest way to do this? Quote
developer_mm Posted May 22, 2018 Report Posted May 22, 2018 Hello patrik, the easiest way to create such a building would be to use a new 3D system with a map section. There you can draw the building according to the map.  See also https://youtu.be/WcKrsm3cMjU (german) or https://youtu.be/TiUaaZddJrI (english)  Kind regards, Marcel  Quote
patrik k Posted May 25, 2018 Author Report Posted May 25, 2018 Thank you. This i already know how to do, the problem is that the roof is pitched in two ways so the irregular building has to have a roof that pitches Booth ways., Quote
developer_mh Posted May 25, 2018 Report Posted May 25, 2018 Hey Patrik, in this case you would have to extrude one half of the building first, edit the inclination of the roof and then extrude the other half of the roof. Hope that helps, kind regards, Martin Quote
