Ralph Posted February 5, 2018 Report Posted February 5, 2018 Hello PV-sol, For a new project a have to acquire values for p50 and p90. I've found this already: If I understand correctly, there should be a way to access a  "Bankability: Exceedance probability of forecast yield" dialog from the financial analysis page. However on the financial analysis-page of my PV-sol 2018 PRO(screenshot attached) I see no way to enter the bankability dialog box. I am missing something? Hope to hear from you soon. Many thanks. Greetings, Ralph van Leeuwen Quote
developer_mh Posted February 5, 2018 Report Posted February 5, 2018 Hi Ralph, the P90 option is only available for project with full grid feed in. In your project you have a system with electrical appliances, the full grid feed in is only available when you don't use consumers. The background is that a P90 analyses can't be calculated because some of your PV energy will be directly used by the appliances. The ratio of the own consumption is a result of the time series based simulation, and that means that we would have to manipulate the input of the PV system simulation (the irradiance data) to be in accordance with the annual value of P90. And this is impossible, unfortunately. Hope that helps, kind regards, Martin Quote
Rodrigo. C Posted March 2, 2023 Report Posted March 2, 2023 Hi, Is there any possibility to obtain de .csv with the p90 parameters? Thank you  Quote
developer_mh Posted March 6, 2023 Report Posted March 6, 2023 Dear Rodrigo. C, no, this is not possible, I am afraid. The P90 values of the irradiance for example are not available in the form of time series, so no csv export possible. Kind regards, Martin Quote
Sascha N. Posted January 24, 2024 Report Posted January 24, 2024 Hello, I would like to use the P50/P90 tool and have two questions: 1. Where are the results displayed in the report? Is it possible to include them as an additional section, in form of a table or diagram? 2. In my simulation, the total PV-generated AC-energy is slightly higher than the P50-value shown in the bankability-dialog. Also after running the simulation several times the values are not the same. Thanks for your help. Best regards, Sascha  Quote
developer_fw Posted January 25, 2024 Report Posted January 25, 2024 Hello Sascha N. On 1/24/2024 at 10:44 AM, Sascha N. said: 1. Where are the results displayed in the report? Is it possible to include them as an additional section, in form of a table or diagram? Are you referring to the diagram which is shown on the page Financial Analysis? This Diagram so far is not part of the results for the project reports. Results are marked with the set probability: On 1/24/2024 at 10:44 AM, Sascha N. said: 2. In my simulation, the total PV-generated AC-energy is slightly higher than the P50-value shown in the bankability-dialog. Also after running the simulation several times the values are not the same. Could you give an example and/or a .pvprj file? Kind regards Frederik Quote
