Boris Posted December 12, 2016 Report Posted December 12, 2016 Dear Team: I need to limit the feed-in power at the conection point and I don´t sure if the Máximum feed-in Power Clipping is the tool for that. For example, if I have a 100 kW PV plant for use in own consumption and I have a feed-in limit of 25 kW, then would I have to put the Máximum Feed-in Power Clipping in 25% of PV Power at the feed in point? Thanks a lot. Regards, Boris Quote
developer_mh Posted December 13, 2016 Report Posted December 13, 2016 Hi Boris Yes, that is exactly the right option to choose. The Maximum Power Clipping percentage always refers to the installed PV power on the DC side. So if you have 100kWp installed and need to limit your feed-in into the grid to 25kW (on the AC side), you set it to 25%. Whether you clip the power after the inverter or at the feed-in point only really matters if you have loads/batteries/e-vehicles in your system. Energetically of course the best option is to limit the feed-in power at the feed-in point, but not all inverters are capable of doing so. Kind regards, Martin Quote
Boris Posted December 13, 2016 Author Report Posted December 13, 2016 Thank you again Martin. Kind regards, Boris Quote
Habibullah Posted October 11, 2020 Report Posted October 11, 2020 Hello Sir/Madam If I feed all the generated power to the grid, in this condition I should not mark the Maximum feed in power clipping, is it true? Quote
developer_mh Posted October 12, 2020 Report Posted October 12, 2020 Hi Habibullah, yes, this is correct. Kind regards, Martin Quote
Dinko Posted April 1, 2021 Report Posted April 1, 2021 HI, I put 31,86 kW on DC side and 71%, because i havent to exceed 22,5 kW on AC side. I get cca 48000 kWh per year. That is in PVSOL Premium. On SMA tool I put 22,5 kW limitation and I get 43000 kwh per year. When I calculate on PVSOL online I get 44132 kwh. On PVSOL online i can't limit. Quote
Dinko Posted April 1, 2021 Report Posted April 1, 2021 Do I something do wrong? All calculations are with same SMA inverter, and Luxor 320W panel. Quote
developer_mh Posted June 8, 2021 Report Posted June 8, 2021 Hi Dinko, sorry the for the late answer. These simulation results are very hard to compare, since all tools use different input data, e.g. climate data, different algorithms to model the system components and so on. PV*SOL on you computer and PV*SOL online use the same algorithms, but at the moment the online version uses climate data from an older version of Meteonorm. This will be updated soon. Kind regards, Martin Quote
Andreas Posted August 19, 2022 Report Posted August 19, 2022 Hi, In my situation I have a 2MWp solar installation connected to 1.3MVa inverter power. The maximum grid connection is 630 KVa and a maximum contracted power of 400 KVa, due to grid congestion is it not possible to get more capable power. My client has a very high energy consumption. The quarterly values has been added to my design. The value of 400KVa is leading and cannot be exceeded. What setup must I use to apply the limit of 400KVa. I think maximum feed-in power clipping at feed-in point set on 20% or 30%. depends on which data I need to use. Is it maximum WP (solar panels 20%) or KW (inverters 30%)? Kid regards, Andreas. Quote
developer_mh Posted August 19, 2022 Report Posted August 19, 2022 Hi Andreas, the maximum feed-in power clipping is related to the nominal DC power of the modules in kWp. So the value would be 20%. Kind regards, Martin Quote
Soheil Komilian Posted February 19 Report Posted February 19 Just to clarify on this matter, If our DC/AC oversizing ratio is not 100%, then the clipping we need to put should not be the export limit (or capacity) we want divided by the total TIC (DC kWp). Example, We have installed 1300kWp of panels (DC), and connected it to 1000kW of inverter (AC), the grid/DNO has asked for export limit of 250kW. Solution: 250/1000 (for AC) which is 25%, and that should be the input for the clipping. if we device the 250kW by the 1300kWp, then the oversizing of the inverter has not been considered. Can someone please clarify this? Quote
hotline_oh Posted 23 hours ago Report Posted 23 hours ago Dear Soheil Komilian, Thank you for your inquiry. If you set a maximum feed-in power clipping at 250 kW: ...then the clipping takes place at 250 kW: If, on the other hand, you set a maximum feed-in power clipping at 25 %: ... then the clipping takes place at 325 kW: Quote
