User defined inverter (new huawei) by OND-file
Hi,
Is it possible to add a new inverter to PVSOL by using OND-files in a similar way like new modules through the PAN-file?
I have already created a user defined inverter for the Huawei 115KTL-M2 by copying the previous 100KTL-M1 and then changing certain values. But since all the values are not 100% correct i would like to create the inverter more accurately by using the OND-file I have.
IF not possible I wish that PVSOL will add all the new Huawei ASAP. For example the 100KTL M2, 115KTL-M2 & 330KTL-800V
Thanks in advance.
Hi
I am new to PV*SOL and would like to know who can assist with adding Inverters to the Database.
There are multiple Inverters that are not listed , mostly inverters that we use in South-Africa.
Thank you
Regards
Hello URBSolar,
within the database dialogue of inverters, you can create new inverters and input data from datasheets:
Please also refer to our online help if in doubt with what to put for certain values: https://help.valentin-software.com/pvsol/2023/en/databases/components/inverters/
Additionally you can write an email to our database team for product requests (database@valentin-software.com). We will then contact the manufacturers.
I hope this helps.
