Ing. Vojtech Vyborny Posted May 5, 2022 Report Posted May 5, 2022 Hi, I´m using PvSol premium for few months, but early this week PvSol shows me notification "The circuit diagram could not be created" for the first time. I made all steps like always - inverter configuration control is OK (green), simulation is running normally, no orange triangles warnings, but scheme of "energy flow graph" in results is gone and also "plans and parts list" page is empty. I can make results without these two pages (diagrams). I tried restart PvSol and PC too. Notification will apper in new project and also in recreating old projects. Will be gratefull for advice, what I´m doing wrong. Thank you. Quote
developer_fw Posted May 5, 2022 Report Posted May 5, 2022 Hello Ing. Vojtech Vyborny, our hotline has informed me that they are already in contact with you. Best regards, Frederik Quote
Ing. Vojtech Vyborny Posted May 9, 2022 Author Report Posted May 9, 2022 Yes, that is true. I sent it here and valentine hotline in same time. We are in touch, but still with no solutions. Thank you. Quote
michalmitro Posted October 2, 2023 Report Posted October 2, 2023 I'm having a same issue. could you please post a solution to this problem? thanks Quote
developer_mh Posted October 4, 2023 Report Posted October 4, 2023 Hi michalmitro, could you contact our technical support team, please? Along with your customer number and your log files, so that they can help you out. Most likely it is an issue with a path or directory that is not found or access privileges are missing or so. https://valentin-software.com/en/support/technical-support/ Kind regards, Martin Quote
