CodrinSomesan Posted May 3, 2022 Report Posted May 3, 2022 Dear users, please help me to understand when / where the CABLE PLAN option designs is available! Please look at the image and help me to understand why the menu is not complete? Where? Or Witch type of the construction will allow me to plan the cable plan? Thank you in advance! Best regards. CS Quote
developer_fw Posted May 4, 2022 Report Posted May 4, 2022 Hi CodrinSomesan, the cable plan design is not available for more than one module area. As you connected two different module areas, the buttons in the ribbon bar are not visible. The solution is to only use single module areas. I hope that helps and best regards, Frederik 1 Quote
Michal Posted June 21, 2022 Report Posted June 21, 2022 Hello Frederick, will be this function add in the future ? ( I mean for module mounting). It will be very helpful. Thank you for reply Michal 1 Quote
CodrinSomesan Posted June 21, 2022 Author Report Posted June 21, 2022 On 5/4/2022 at 3:37 PM, developer_fw said: Hi CodrinSomesan, the cable plan design is not available for more than one module area. As you connected two different module areas, the buttons in the ribbon bar are not visible. The solution is to only use single module areas. I hope that helps and best regards, Frederik Thank you very much! I will keep in mind! Quote
Kitty Posted March 9, 2023 Report Posted March 9, 2023 I have been having the same issue (only page preview appearing in cable plan) but I have rearranged my panels to be in one module area and the cable plan options are still not appearing. It is working when I configure with Solis but not when I configure with SolarEdge. Can you tell me why this might be? Thank you Quote
developer_mh Posted March 13, 2023 Report Posted March 13, 2023 Hi Kitty, this is correct, the cable plan is currently disabled for polystring (multiple module areas on one MPP tracker). For SolarEdge configurations, the polystring option is enabled by default. If you only have one module area you can uncheck that option. Then you can use the cable plan feature: Hope that helps, kind regards, Martin Quote
Levan Posted May 6, 2023 Report Posted May 6, 2023 @developer_mh@developer_fw could you please check what is wrong here. cable plan disabled. Quote
developer_fw Posted May 8, 2023 Report Posted May 8, 2023 Hi Levan unfortunately the cable plan is not working across multiple module areas, if that is what you are trying to achieve. Kind regards Frederik Quote
ANNIEKS Posted January 27, 2024 Report Posted January 27, 2024 Could you please check what is wrong here? As I only have one building with flat roof top plus one module type and one inverter. Thanks! Quote
developer_fw Posted January 30, 2024 Report Posted January 30, 2024 Hello ANNIEKS I responded to your duplicate request here: Kind regards Frederik Quote
