February 23, 20224 yr comment_6833 As the title says I've run into an issue. This is the first time that I have this problem and I think that it might be related to the 2022 (R4?) release since I just got that yesterday. Anyway here's what PV*SOL shows as map data when selecting Google satellite And here's the same place when I check it in a browser It seems like PV*SOL is getting old data from Google even though it says that the data is from 2022, I can assure you that this data is at least 2 years old. I can work around this so it's not a big deal for this case but I don't think that it's supposed to be like this and I've never seen any discrepancy between PV*SOL's map and the browser map before. Report
February 23, 20224 yr Author comment_6834 After a bit of digging this isn't a 2022 issue since I get the same results in 2021. Maybe I'm just lucky that I've never encountered this before. If I understand correctly the map data isn't actually Google map data but rather Tele Atlas data. Is that correct? Report
February 23, 20224 yr comment_6836 Hi Jimmy, thanks for reporting this, and thanks for the coordinates as private message. We will be able to fix this in the new version PV*SOL premium 2022 R5. Kind regards, Martin Report
March 14, 20224 yr Author comment_6937 Hi Martin, When will R5 be released? I'm getting a lot of these outdated maps and it adds extra and less precise workflow since I have to screenshot the maps and do the measurement manually. Kind regards Report
March 15, 20224 yr comment_6948 Hi Jimmy, we are sorry that you are experiencing this flaw with the outdated maps more often now. It seems that Google is updating its map material region-wise, and most probably you are planning a lot in a region where Google is currently updating. We do not have a release date for R5 yet, I am afraid. It will be released in the coming weeks, but when exactly is not yet decided. Kind regards, Martin Report
March 24, 20224 yr comment_7012 I've experienced this too, though more often than not, switching to the other options available; Bing map, Bing hybrid map or Google Hybrid map is magic, and works well Report
March 24, 20224 yr Author comment_7015 Google Hybrid actually seems to work well! Thanks a lot Jordn! Report
