diegov Posted February 20, 2015 Report Posted February 20, 2015 Dear fellow PVSol users and administrators, Â How can I select just one inverter when I have multiple orientations in PVSol? Â I'm simulating a photovoltaic system for a building with 3 different orientations with 3 roof areas in each orientation that in PVSol are 12 module areas in total (as shown in the thumbnails ), but I can't configure all the 12 selected areas together in a single inverter . Â I would be very grateful for any help you are able to provide. Quote
hotline_sf Posted February 25, 2015 Report Posted February 25, 2015 Hello diegov,  For that specific situation you have to use the "Group Module Areas..." option in the "Module configuration" window.   In the opening window please press the "Import all unconfigured modules" button. Now you should have 12 module groups in the window. Select now module groups with the same orientation and tilt angle (set a hook). Afterwards use the "Combine selection" button to group the selection.   Do this for all module groups with the same orientation and tilt. At the end you shoulf have 3 module groups. Now you can use the "Configure" button to open the inverter selection window.   In the inverter selection window please mark the 3 module areas by using your mouse and the CTRL key of your keyboard. If they are marked you can use the "Configure selected module areas together" button to combine them. Now you can search for an matching inverter with 3 MPP trackers.   Best regards  Your Support team Quote
diegov Posted February 25, 2015 Author Report Posted February 25, 2015 Thnaks Support Team for your answer as always. I will try it as soon as I have time to. Quote
developer_mh Posted March 7, 2017 Report Posted March 7, 2017 Hi, we now also have a short tutorial video on youtube that shows how to connect two module areas to one MPP tracker: Cheers, Martin Quote
