June 7, 20215 yr comment_5550 Hello! I tried to update to 2021 R6 an got the error "An error occurred while trying to replace the existing file: DeleteFile failed; code 5." See screenshot. Is it fine to ignore and skip? Thanks, Frido Report
June 7, 20215 yr comment_5551 Hi Frido, normally, a window opens informing about running instances that have to be closed before an installation. It might be that a "dead" process is still running but the GUI crashed. This might explain why our usual warning does not show. A restart of your computer should end such processes, did you already try a reboot? If this is not working, delete the folder C:\Program Files (x86)\Valentin EnergieSoftware\PVSOL premium 2021\ manually before installing. Best regards, Frederik Report
