Hi there! What format you are using for your 3D model?
Here is a document with a list of supported formats:
https://www.valentin-software.com/wp-content/uploads/legacy-downloads/sonstiges/en/3d-recherche-rev-01-en.pdf
I have had the best results using .dae or .obj files in the past. However, I have found 3D models to be very unreliable (invisible walls that casting shade, module areas floating mid-air after saving the file etc.) so personally I try to avoid them when ever possible.
Hope this helps. Regards,
Frido
  • Like 1
  • Thanks 1
Hello Fayez,
thank you for your request. It is hard to tell what exactly went wrong, but most of the times the 3D models are broken in a way PV*SOL cannot handle. Check your models before the import and try to simplify your models as far as possible. The less vertices the faster the simulation.
Best regards,
  • Like 1
