Reint Posted July 16, 2020 Report Posted July 16, 2020 Hi! For some reason 14 inverters from the brand Autarco cannot be deselected when I'm trying to generate an automated configuration by PV Sol. When I select all inverters from Autarco the selected inverters add up to , but when I deselect all inverters, PV Sol still keeps 14 inverters in my selection. Quote
developer_mh Posted July 16, 2020 Report Posted July 16, 2020 Hi Reint, this is strange. Is it possible to provide a screenshot or a short screencast of the problem? If you don't want to share it publiclyyou can send me a private message here in the forum. Kind regards, Martin Quote
developer_mh Posted July 17, 2020 Report Posted July 17, 2020 Hi Reint, perhaps there are some Autarco inverters selected that are no logner available? Just check the checkbox in order to see if there is somethng hiding. Kind regards, Martin Quote
Reint Posted August 4, 2020 Author Report Posted August 4, 2020 Hi Martin, I tried to uncheck all the boxes to remove the autarco's from the selection. However, 14 still keep on being selected while I can't see them anywhere. Quote
developer_mh Posted August 10, 2020 Report Posted August 10, 2020 Hey Reint, perhaps you tried the following, I just wanted to make sure that you checked this option in order to see the unavailable Autarco inverters as well: Â Kind regards, Martin Quote
Reint Posted August 12, 2020 Author Report Posted August 12, 2020 Hi Martin, Yes that works, thank you! Quote
Frido Posted August 17, 2020 Report Posted August 17, 2020 I had the same problem, and this helped. Thanks! Quote
