HPJ Posted November 14, 2019 Report Posted November 14, 2019 Hello, I am interested in the format used to import a custom load profile. How should the txt file be formatted? Is it just one row per hour value and then starting at 01.01.?? 00:00? Thanks. /HP Quote
developer_mm Posted November 15, 2019 Report Posted November 15, 2019 Hello HPJ, to import your own load profile, simply place each consumption value in a row and nothing else with the starting point you mentioned. Further information can be found here: https://help.valentin-software.com/pvsol/2019/pages/consumption/#import-load-profile. Kind regards, Marcel Quote
Trond Posted November 22, 2019 Report Posted November 22, 2019 Is it possible to have an example posted? Quote
developer_mh Posted November 25, 2019 Report Posted November 25, 2019 Hi Trond, the attached txt file here contains one value per line, for each hour of the year. The unit is Watts, so you have to choose this in PV*SOL when you import the file. Hope that helps, Martin PVSOL Load Profile for Import.txt Quote
