Hi,
When stringing is there a process after choosing meander?
Most of the time when meander is chosen and then cable design. It automatically keeps the stringing as simple.
Am i missing a step?
Thanks
Dear CarlSEL,
If you have already created a cable plan and subsequently make changes to the configuration, the cable/string diagram is not always updated. You must then delete the cable plan (press the ‘Delete all cables’ button), switch back to the Module configuration page and then back to the Cable plan page. Everything is then updated and the cables run in accordance with the configuration.
21 minutes ago, hotline_oh said:
Dear CarlSEL,
Perfect, thank you
