Vishnu
    9
Vishnu last won the day on February 22 2021
Vishnu had the most liked content!
2 Followers
Vishnu's Achievements
  1. Moin Martin, Thank you for your reply. I check your suggestion to uncheck the High DPI Override and it's already unchecked on my laptop. So tried by checking the check box and surprisingly now the menu bar seems normal. ^^ Do you think I can leave this check box checked? Cheers, Vishnu
  2. Hallo again, The problem still exists. In addition to the main menu bar, the information bar at the bottom of the screen is too small to read. And it sometimes get really uncomfortable as the mouse clicks just do not work. I had to go to a different window and come back to PVSol. I tries reinstalling the software but it did not help.
  3. Hello Frederik, Thank you for your response. It partially solved it. I can now see the main button bar but it is still with relatively small buttons. Is it possible to make it more comfortable like I see it in your screenshot? My PVSol used to be like that before I reinstalled it Cheers, vishnu
  4. I have reinstalled my PVSol and ever since the editing options size has reduced and above all, no matte on which section I am, I see the same editing options. Could you please help me solve this issue. Thank you
  5. Heya Team, I observed on the inverter config page that the module surface orientation is different in the new PVSol version. As you can see in the image, I have two module surfaces facing Nord-west and Nord-ost but the inverter config shows only Nord-west Is this something that has actually been changed in the new version or is it a bug? Thank you!
  6. Hey Valentin Team, I tried simulating one of our PV systems with Fronius ECO 27 inverter, which as per its Datenblatt, has max input voltage of 1.000V The modules I used are SOLON R-WF 120p.2/370 with max Voc of 40,81V There is a warning that max Voc of inverter is crossed when I used 24 modules (24*40,81 = 980V) on one string. What am I missing here?? Thank you!!
  7. To my knowledge, the system operator receives Ausfallvergütung only under special conditions, like when Einspeisevergütung or Direktvermarktung fails. Even then, the operator has to apply for Ausfallvergütung to receive the compensation. So these are very special cases and I don't think it's possible to calculate in PVSol
  8. Hello Lukas, May I ask if you can share a screenshot of Financial analysis page or the project report? May be we can find out something Just curious to see what might go wrong -Vishnu
  9. Hey there, There was similar question on this forum already. Hope it helps
  10. Main input parameter for this is "electricity tariff from grid" which one provides as input
  11. Vishnu
    UNDO
    Hey Marcel, There is no undo function available in PV*Sol. I remember one of the admins mentioning that implementing undo function is pretty complex. We can consider ourselves lucky should it be on the wishlist -Vishnu
  12. Hallo there, I was wondering if there is a possibility to add power price (€/kW) in addition to energy preis in PV Sol or is this still on your wish list? Thank you, Vishnu
  13. You can get rid off them by setting the distance to edge to zero in "Edge distances"
  14. Hello Lukasz, You can only do that by selecting a 3ph inverter instead of a 1ph inverter. -Vishnu
  15. Hi Miguel, To my knowledge I haven't seen any option in PVSol to set the life-time of the battery. May be PVSol considers the degradation of the battery which inturn impacts the efficiency and eventually the energy that can be stored in the battery. -Vishnu
