55 -
Everything posted by timgreen13
Dear Frederik Thanks you for the answer. if i would like to estimante the % of total energy coming from the rear side ,is my cacluation ok ? so (24.8524.85kWh/m2 *4355m2)-32466kWh(bifacialty loss)=75755 75755/816889=~9% gain in energy from the rear side is this correct ? Thanks
- 4 replies
- bifacial modules
- bifaciality
(and 1 more)
Dear Support (or users) i have a project that i did using bifacial moduls. 1.in the energy report i would like to know what is the % of total energy coming from the rear side? where i can see this ?(i see just the gain in irradiance) 2.and how the -0.66% (bificiality 70%) is calculated Thanks
- 4 replies
- bifacial modules
- bifaciality
(and 1 more)
well this is first time after the update to 2021 ..
hi it will be much easier for you to draw it in sketchup and import it in to PVSOL ilia
if you mean like in pvsyst , i sure that pvsol didn't have this option
Changing module mounting inclination on existing simulation
timgreen13 replied to RicardoM's topic in PV*SOL
nop -
hi, you mean that you dont see what i see ? ? im using the last version(but the trail 30 days) i also tested it on other laptop (full version of 2020 R5) and got the same results
Hello, i'm doing a a project with complex roof . i set all the edge distance on 0 but still they are appear ...why is that ? see pic below(aslo the proj file) Yoshvia proj.pvprj
@RicardoM the cable plan is not working on mounting systems
import 3D model fallacy - beware of its very limited usefulness
timgreen13 replied to Joao Prates's topic in PV*SOL
Hi Joao Prates Thank you for the detailed information ! So one question ..do you know approx what the max size of area m2(3d building) that i possiable to import(after you drone him) and still have a good resalution ? thanks- 5 replies
- crash
- shading simulation
(and 6 more)
Hello From my expireance and how i work is that for utiliy project (more then 3 MW) i'm using PVSyst ...less then that PVSOL the 2D mode is very weak to handeling big project-my opinion Thanks
Trina Tallmax TSM-DE15M(II) 400W and Jinko Cheetah HC JKM340M-60H-V
timgreen13 replied to Daniel's topic in PV*SOL
one more question what is the reason that in the database there is a pv modul (for example) but i can't find it on my PVSOL database(i have fully liecened +updates) thanks -
and what is going to include :)))
Dear Support, Is it possible to see how the cable losses are divided(by % or W) per string , for example i have 12 strings and the DC cable losses are 3% , which of this 12 strings got the st loss
Dear Developers, i'm "playing" little bit with the cables planner just to see how it works and etc. i made this for example(questions below): why the cable losses AC are 0% -what i need to do in order to see something :)? because i tried to change allot of things and it's always 0% another thing: if i confirm the design above and will go to the cable losses : 1.why on the schematic drawing there is no information from the 3D cable modeling (cable length and etc.) the only thing that has some connection is the 0.95%(in gray) that mean if i want i can put it in the total losses right? Thank you!
Thank you very much for your answer !
- 5 replies
- consumption
- load
(and 2 more)
So if i understated right , if i only 12 values for consumption for each month (i don't have hourly/or by minute) for example jan-100 kwh feb-200 kwh mar-300 kwh and etc. i need to create consumption file accordingly ? and import it there is no direct way? just put the consumption value for each month (like in Aurora?) thanks
- 5 replies
- consumption
- load
(and 2 more)
Dear PVSOL support, i would like to add monthly consumption to PVSOL, for example for each month from 1-12 to add his consumption(not the annually) what is the best why to do it? i tried to play with the % of the standard year -by dividing monthly consumption by yearly but the end result is not accurate
- 5 replies
- consumption
- load
(and 2 more)
Hello, i saw that R11 was updated. in the release note was written(see below), can you please explain the second point
ohhh got it ! thank you:) So the 2014 is making a confusion ?
Dear Martin, ? i didn't understand where is the confusion? "This is because we only simulate one year" -why? , which year? thanks
Thank you very much! especially for the tomatoes example :)))
