Hello,
can the PV*Sol Premium 2025 version be used to model a solar power plant on uneven terrain, if there is a surveyor’s topographic map with contour lines available?
Thanks in advance!
Hi Gordana,
you can import 3D models in PV*SOL, no problem. You can also import terrain data via the Google Solar API. But the design of real large scale solar plants on uneven terrain is not what PV*SOL is made for.
Best regards,
Hello Martin,
Thank you for your answer, here is my problem... I made a terrain in SketchUp, and I exporeted it as a obj. file, and then imported in my pv sol project as terrain, but it is not possible to mount pv panels on my imported terrain so what I could do? I am not sure how I can use Google API regarding this terrain issue. I am attaching here my project for you to see. Solar plant that i inted to make would be less than 150 kWp, ground mounted, but it is important to be realisticly mounted because these terrain has slopes... Thanks in advance!
Šipovo.pvprj Sipovo.skp
Hi Gordana,
in order to be able to place modules or mounting structure onto the terrain, you'll need to add mounting surfaces first. These mounting surfaces are flat (two-dimensional) and adapt to the inclination of the terrain. However, you can only place modules inside the boundary of such a mounting surface. Also, the mounting posts will be perpendicular to the mounting surfaces, so really not vertical.
Here is a quick draft of what you can achieve if you choose to go that way. If you just want to have a shading analysis and the yield simulation, you can surely go this way. If you need to have the exact length and position of the mounting structure, or mounting structures without gaps in between, or anything more advanced, you can not use PV*SOL for that, I am afraid.
