April 4, 20197 yr comment_2384 Greetings, I use Autodesk's Recap Photo to generate 3D models (.obj) from drone pictures I take of rooftops, then I import the .obj files on PV*SOL. This all worked very well but now I'm getting an error everytime I try to import a 3D model: "Error on loading the file" I'm aware that PV*SOL doesn't handle models that have over 500.000 vertices, but PV*SOL stopped importing models with under 200.000 vertices, that have around 20 mb. Is there a way I can send you the .obj file so you can test it? Report
April 8, 20197 yr comment_2393 Hi Vicente, could you send us the 3D model (the obj file), so that we can have a look? Thanks, Martin Report
November 26, 20196 yr comment_3162 Hi. I'm having the same problem! I cant import any .obj file on PV SOL! And it crashes all the time. I've looked everywhere and couldnt find how exactly are the configuration accepted on PV SOL for .obj files (ex. number of pixels, points, etc..). I've tried also different sofwares to creat the models, but all neither worked. Report
November 28, 20196 yr comment_3171 Hi Stefany, could you send us the 3D model (the obj file), so that we can have a look? Unfortunately we haven't received a file from Vicente, so we don't know the reason there. Thanks, Martin Report
September 2, 20224 yr comment_8536 Hello, i am having the same problem. Here is download for the .obj file. PVSol says that the format is incorrect. https://wetransfer.com/downloads/34a0dc1b3380a0784841c397cc19a81a20220902104726/e79385/grid Have a nice day, Tejnsky. Report
October 14, 20224 yr comment_9013 Hello OnTe_, sorry for coming back this late to you, your request got lost. Could you send the file again? Kind regards, Frederik Report
May 4, 20233 yr comment_13318 Hello, Im having a same issue, cant import 3D model (.OBJ file) to PVSol 2023 R4 on Windows 11. Even though the same 3D model works perfectly fine on Windows 10 machine on same version of the program.. I hope some one can find a fix for this. Report
May 8, 20233 yr comment_13348 Hello Leonardas On 5/4/2023 at 4:44 PM, Leonardas said: I hope some one can find a fix for this. Sorry about the belated answer and the issue you have encountered! Could you please send me the relevant file via private message here in the forum so we can have a look into it on our machines? Thank you in advance! Kind regards Frederik Report
