i have modules facing two directions - south west and south east. i can go for different inverters for different orientations but when i am trying to connect all the modules together i do not see an option to select different inverters
for Eg: i can select two solaredge SE 25k inverters but what i want is 1 SE 33.3k and 1 SE 10k. please suggest how to proceed
Hello Vishnu,
Select all desired module areas and press the button "Configure module areas together". Then you can connect each module area to an mpp tracker. If you want to have all module areas on one mpp tracker, you have to select "Polystring Configuration".
There is only one limitation, after that you can only use one inverter. If you want to use more than one inverter, you have to split your module areas. image.png
Marcel
