Marta Gonçalves Posted March 24, 2019 Report Posted March 24, 2019 Good night,I have had many problems with PVSol projects based on the 3D import of sketchup. I can not simulate project shadowing. I've been trying all day and the program locks up and turns itself off.I need your help to solve this program problem. Quote
developer_mm Posted March 25, 2019 Report Posted March 25, 2019 Hello Marta Gonçalves, Could you provide us the project file (by private message or here by post)? Then we will have a look at it. Kind regards, Marcel Quote
Marta Gonçalves Posted March 25, 2019 Author Report Posted March 25, 2019 Good Morning, Thank you for your help. I'll send the project. Can you provide me an email given here just to be allowed uploads up to 5.3 MB? Quote
Marta Gonçalves Posted March 25, 2019 Author Report Posted March 25, 2019 4 hours ago, developer_mm said: Hello Marta Gonçalves, Could you provide us the project file (by private message or here by post)? Then we will have a look at it. Kind regards, Marcel Marcel,Can you give me an email address to send the project?Thank you Quote
Marta Gonçalves Posted March 25, 2019 Author Report Posted March 25, 2019 Marcel,Can you give me an email address to send the project?Thank you Quote
GeromeK Posted March 26, 2019 Report Posted March 26, 2019 You can send it via PN, if you click on the user "developer_mm" you can send him a message with an attachemnet Quote
developer_mm Posted March 27, 2019 Report Posted March 27, 2019 Hello Marta, Have you tried these options, Martin recommended ? Especially these steps from the pdf: Quote SketchUp SketchUp is a software for creating three-dimensional models and is available in the versions Make and Pro. The free SketchUp Make of-fers the possibility to export 3D models in * .dae format. Go to File -> Export -> 3D Model and select COLLADA (* .dae). Before exporting the file, open the options menu and select the following export options: Triangulate All Faces Export Texture Maps Export Edges Export Two-Sided Faces https://www.sketchup.com Unfortnuatly problems with the 3D Models can be pretty hard to fix, but we will see. On 3/25/2019 at 10:27 AM, Marta Gonçalves said: Good Morning, Thank you for your help. I'll send the project. Can you provide me an email given here just to be allowed uploads up to 5.3 MB? The upload limit in the private messages should not be so low. It should work, I just tried it myself. Kind regards, Marcel Quote
