JDrojas Posted February 18, 2019 Report Posted February 18, 2019 hola soy nuevo en la utilizacion del sotfware, yo nesecito obtener la trayectoria solar solar sobre el lugar de instalacion con el PVsol Premium; como se realiza en este software. gracias por su ayuda quien me pueda responder. Quote
developer_mm Posted February 19, 2019 Report Posted February 19, 2019 Hi JDrojas, I've transalted your message in english, so that everyone can read your question (including me): Quote hello I am new in the use of software, I need to get the solar path on the site of installation with the PVsol Premium, as is done in this software. thank you for your help who can answer me. Translated with www.DeepL.com/Translator I am not quite sure what you gonna need, because the transaltion isn't that accurate. I'm not quite sure what you need because the translation isn't that accurate. If you would like to buy PV*SOL premium, you can do so he https://shop.valentin-software.com/collections/produkte/products/pv-sol-premium If you need a trial version, you can download it here http://downloads.valentin.de/pvsol/setup_pvsolpremium_2019_6.exe The standard installtion path would be C:\Program Files (x86)\Valentin EnergieSoftware\PVSOL premium 2019 The standard path for the pvsol user files would be here: C:\Users\NAME\Documents\Valentin EnergieSoftware\PVSOL premium 2019 I hope I could answer your question, Kind regards Marcel Quote
developer_mh Posted February 19, 2019 Report Posted February 19, 2019 Hi JDrojas, let me add to the comments of my colleague, that if you need the sun path at the location in question, you can see it in the results. Go to the page "Results" (Resultados) and then Diagram Editor (Editor de diagramas) and select sun height (altura del sol): Another possibility is to go to the PV module page (módulos FV), then to the shading (sombreado) and then select horizon shading (línea del horizonte). There you get the solar path diagram: Hope that helps, Martin Quote
JDrojas Posted February 23, 2019 Author Report Posted February 23, 2019 ok gracias si esa es la trayectoria del lugar escogido es excelente el resultado muchas gracias. Quote
JDrojas Posted February 23, 2019 Author Report Posted February 23, 2019 hola pero tengo un problema; pese a que tiene la localización y demás en el software, no me reporta la trayectoria solar me toca ingresarla manualmente y no se que ingresar pense que solo con la localización el sofware es capaz de deteriorar la trayectoria sobre el lugar indicado; no aparece nada me dice que importe o que agregue como se que la informacion suministrada es la correcta. Quote
Jon Posted February 24, 2019 Report Posted February 24, 2019 Hola JDrojas, Lo que te está pidiendo que intruduzcas no es la trayectoria solar sino el sombreado del horizonte, que es el sombredo que puede proyectar un edificio muy lejano o una montaña. Te paso link un sistema para definir ese horizonte denominado Horizon de The Solar Design Company, para que te hagas una idea de los datos que te pide introducir el programa - https://www.solardesign.co.uk/horizon.php - La trayectoria solar te sale automáticamente definida una vez has decidido la ubicación con los datos climáticos, de acuerdo a la trayectoria solar que muestras tu habrás definido el sistema en un lugar próximo al ecuador terrestre. Si terminas de definir el sistema podrás pasar a una interfaz de resultados donde puedes ver la trayectoria solar diaria tal y como te señala developer mm. Un saludo Quote
