xguil Posted November 29, 2023 Report Posted November 29, 2023 Hello I am trying to install your PVSOL program to test it, since I am very interested, but it gives me an error. I am installing it on a MAC M2 that runs Windows 11 in parallel. When installing it it tells me that it is only possible to put it on X86 and X64 processors (this processor is ARM) The version I am installing is 2024_1. The issue is that a colleague tested the 2023 version with the same system and says that it worked perfectly. Thank you so much Quote
developer_fw Posted November 29, 2023 Report Posted November 29, 2023 Hello xguil hello dear users in general we fixed the error for ARM architectures and are working hard on publishing version 2024 R2 tomorrow. We are very sorry about any inconveniences caused by us! Kind regards and thank you for your patience! Frederik Quote
developer_fw Posted November 30, 2023 Report Posted November 30, 2023 Hello dear customers We just released PV*SOL premium 2024 R2 including the ARM bugfix: https://valentin-software.com/downloads/ Kind regards Frederik Quote
dj_prism_ Posted January 16, 2025 Report Posted January 16, 2025 Hi, is it possible to run PV Sol in 64 bits on ARM VMs ? is it hard to find anything on the web... Quote
hotline_oh Posted January 20, 2025 Report Posted January 20, 2025 Dear dj_prism_ Thank you for your inquiry. Running PV*SOL premium on a virtual machine works without problems for many of our customers. Make sure that the virtual machine can provide the required 3D hardware support. Please check how the graphics resources are allocated to the VM. At least DirectX must be supported. The graphics may not support OpenGL or Direct3D or the functions may need to be switched on. General system requirements: Internet connection Processor: Intel i3, AMD Ryzen 3 or higher RAM: 4 GB Hard disk space: 1,2 GB Resolution display: at least 1.280 x 768 pixels Operating system: Windows 10 (64 bit, latest service pack required), Windows 11 (64 bit) Graphics: DirectX compatible (at least Version 9.0c), 2 GB, OpenGL Others: Microsoft .Net Framework 4.8 We recommend that you download our free trial version and check whether PV*SOL premium runs on your device. Quote
