jamesbm Posted November 9, 2018 Report Posted November 9, 2018 Hi, Any suggestions what might have caused this error? I updated an old model by changing an inverter and adding specific cable dimensions. The error occured when I clicked on thew results button. The file is now corrupted and I can't re-open it. I have submitted an error report. Please help! Quote
jamesbm Posted November 9, 2018 Author Report Posted November 9, 2018 I have just repeated the process. The inverter change was fine. The issue seems to be trying to run results after adding specific cable details. Annoyingly even without saving after changing the cable details the original file is corrupted and can no longer be opened. Quote
developer_mm Posted November 9, 2018 Report Posted November 9, 2018 Hello jamesbm, Thank you for telling us. We are aware of this error, but we have no idea what is causing it. Could you send me your project by private message? Could you also give me more information about what you did? Kind regards, Marcel Quote
jamesbm Posted November 9, 2018 Author Report Posted November 9, 2018 Hi I have sent the file. Hopefully you can suggest a way to fix this. Thanks James Quote
developer_mm Posted November 12, 2018 Report Posted November 12, 2018 As Information for all Users, this problem will be fixed in the next PVSOL Version (2019 R3). Quote
jamesbm Posted November 14, 2018 Author Report Posted November 14, 2018 thanks for your efforts. Quote
