Ricardo Posted November 7, 2018 Report Posted November 7, 2018 Hi, I got the following error and do not know what it means nor how to solve it: Â Â I was working on a project and saved it successfully, then went on to create more buildings in the 3D Design area. When I did, PV SOL asked whether it was OK to delete the shading simulation, which I accepted. I then tried to exit the 3D Design and was prompted to simulate shading, which I declined, as I was not done yet (I had already configured some modules with their inverters). Â And then when I tried to save my project that error popped up. Am I doing something wrong? I had previously created other buildings and it was not a problem. Â Thanks for your support. Â Quote
developer_mh Posted November 7, 2018 Report Posted November 7, 2018 Hi Ricardo, could you send me your log file under C:\ProgramData\Valentin EnergieSoftware\log per private message, please? Thanks a lot in advance, Martin Quote
developer_mh Posted November 8, 2018 Report Posted November 8, 2018 So, just for the record, and in case that other users have a similar problem: In PV*SOL premium 2019 R2 there is a bug that can occur when you have the following setup: you edit a 3D project were shadows have already been calculated You add more objects in 3D so that the shading calculations are deleted Then you leave 3D, adopt the data to PV*SOL, but you don't recalculate the shadows When you then try to save the file, an error might occur, depending on the inverter configuration you have We will fix this bug in the next release. For now you can save the projects when you calculate the shadows again. Sorry for the inconvenience, Martin Quote
Yvar BAM Posted November 9, 2018 Report Posted November 9, 2018 (edited) Dear Martin, I have another bug in the R2 version; It is not possible to select single modules in the mounted version. You can only select entire rows so it is not possible to just use 10 of the 100 modules to connect to a inverter.  Is the new release coming soon? I really need this function... (for now, is it possible to download the older version of the program?) Kind regards  Yvar Edited November 9, 2018 by developer_mh full quote removed Quote
developer_mh Posted November 9, 2018 Report Posted November 9, 2018 Hi Yvar, we just tested it again and here it works fine. Just ensure that you enable the corresponding option in the panel of the module configuration: Hope it helps, kind regards, Martin Quote
Yvar BAM Posted November 9, 2018 Report Posted November 9, 2018 (edited) haha o, yes, that helps xD. It was always on in the previous version, so I never thought of trying the buttons. Thank you! Edited November 9, 2018 by developer_mh full quote removed Quote
Ed@NL Posted November 11, 2018 Report Posted November 11, 2018 thanks, I had the same problem. good to know what the cause is. the workaround is just to recalculate the shadow when annotating from 3d to calculation and the saving works ! Quote
Ricardo Posted November 15, 2018 Author Report Posted November 15, 2018 Hi Martin and everyone, Is the bug I mentioned fixed in the new release to be downloaded today? I mean the one causing "Error: Object reference not set to an instance of an object" that originated this post. Thanks!! Quote
developer_mh Posted November 15, 2018 Report Posted November 15, 2018 Hi Ricardo, yes, the bug is fixed in the upcoming release, PV*SOL premium 2019 R3. Kind regards, Martin Quote
