Go green BG Posted October 11, 2023 Report Posted October 11, 2023 1. How can I see the parameters of the created systems without removing the panels already placed in the project? 2. "My Solar AS-8M132-BHC-665W" panels are missing from the database. I made a copy of another bifacial panel of the same manufacturer, but I don't know which parameters to enter in the irradiance field. I am attaching a technical specification and a screenshot. 3. Is it possible to have the dimensions and characteristics of the placed panels in the presentation? Thank you in advance Quote
Go green BG Posted October 11, 2023 Author Report Posted October 11, 2023 AS-8M132-BHC Bifacial Half-cell Module Specification.pdf Quote
developer_mh Posted October 12, 2023 Report Posted October 12, 2023 Hi Go green BG, thank you for your questions and the screenshots. You choose to create a copy and then see all the details in the edit dialog. Then choose cancel. I will forward this request to our database team. If you create your own PV modules e.g. by copying existing ones and you don't know the low light parameters, just choose "standard" Yes, the module dimensions are displayed in the dimensioning plan, and are also listed in the PV module datasheet table Hope that helps, kind regards, Martin  Quote
Go green BG Posted October 12, 2023 Author Report Posted October 12, 2023 Hi, Martin 1.      I was hoping for more, but that's kind of an option too. 2.      I specified Standart and Spec. Annual Yield fell by nearly 1,000 units compared to the one-faced ones, which is certainly not the real performance. And how can I delete the versions of the panel that I created, because the program does not allow me to specify which version to use, but makes every correction - the next version. Can you prepare a workshop for the introduction of panels by characteristic from a manufacturer. It would be very helpful! 3.      I don't want to see dimensions of the entire roof in the presentation, but only of the panel. Is it possible to add them to the Parts List automatically along with the brand?  Quote
developer_fw Posted October 17, 2023 Report Posted October 17, 2023 Hello Go green BG On 10/12/2023 at 9:31 AM, Go green BG said: 2.      I specified Standart and Spec. Annual Yield fell by nearly 1,000 units compared to the one-faced ones, which is certainly not the real performance. And how can I delete the versions of the panel that I created, because the program does not allow me to specify which version to use, but makes every correction - the next version. Can you prepare a workshop for the introduction of panels by characteristic from a manufacturer. It would be very helpful! PV*SOL does allow you to use any version of a product! You have to activate visibility for All versions: On 10/12/2023 at 9:31 AM, Go green BG said: 3.      I don't want to see dimensions of the entire roof in the presentation, but only of the panel. Is it possible to add them to the Parts List automatically along with the brand? I forwarded your feature request to the responsible developer. Kind regards Frederik Quote
