Peter_ Posted July 4, 2023 Report Posted July 4, 2023   hi,  I have an issue sometimes that pvsol doesnt show the graph of own consumption, even though. below I have the same project in another file and there it seems to work. I dont really know what is the difference between them.  (the first was a 3d project but I removed the 3d check and it still doesnt show the graphs) this issue started since the r5 update, and we had this problem on several projects now Do you have any idea what it could be? do i have a setting wrong? thanks for your help  Peter  Quote
developer_fw Posted July 7, 2023 Report Posted July 7, 2023 Hi Peter_ On 7/4/2023 at 1:37 PM, Peter_ said: Do you have any idea what it could be? Could you send the two project files via private message here in the forum? Thank you in advance and kind regards Frederik Quote
developer_fw Posted July 10, 2023 Report Posted July 10, 2023 Hello Peter_ thank you for the project files. As assumed the Energy Balance/Feed-in Concept on the page Financial Analysis was different in the project files: Some diagrams are not visible then. When in doubt there also is the possibility to compare several projects: https://help.valentin-software.com/pvsol/2023/en/project-comparison/ Kind regards Frederik 1 Quote
Peter_ Posted July 11, 2023 Author Report Posted July 11, 2023 That solved it indeed! Seems i accidentally changed the feed in concept We are not using the financial Analysis in PvSol so I was not looking for a solution in that direction. Thank you very much Frederik! Quote
